Latest post 01-24-2008 6:44 AM by beojeff. 3 replies.
Page 1 of 1 (4 items)
  • 12-16-2007 11:21 AM
    A.AUX does not work
    I have a BV Avant with a BeoCenter 2.
    On the AUX of the BC2 I have a old turntable. With my beo4 can select it with A.AUX.
    On the Beo5 this switches on the Radio. The code send is:
    0:000:RADIO:AUX_A
    Has anyone an idea?
  • 12-27-2007 4:43 PM In reply to
    Re: A.AUX does not work
    Did you ever try to use PHONO instead of A.AUX? My ouverture is accepting both commands to switch to the AUX input.
    Hagen
  • 01-23-2008 12:25 PM In reply to
    • cone
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Oviedo/SPAIN
    • Posts 598
    I had a similar problem as you. Try to create a new button, do not use the one that was created with your set up (delete it)
  • 01-24-2008 6:44 AM In reply to
    I, too, had a similar problem. In my case, I kept the same button but changed the label of the button to "turntable" and it worked. This makes no sense, but it worked.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
