1st March February 2012
Latest post 12-18-2007 2:03 AM by Peter. 17 replies.
12-15-2007 7:52 PM
damatt
- Joined on 09-14-2007
- Posts 190
Beomaster 7000 and light programming
My Beomaster 7000 used to be in option 1 and therefore I could use it to program my lights (LC2 & LC1) to turn on at a specific time. Now my Beomaster 7000 is in option 0 and it can't control my lights anymore. (It's now connected to a BeoVision 7 which is in option 2)
Is there a solution to this problem?
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Beomaster 7000 and light programming
Well you could put them all to Option 1 but you will need to use the AV key a fair bit. You could use a MCL2A with IT transceiver as just a control mechanism - maybe set as option 4 so it doesn't interfere with normal operations. Seems a bit expensive!
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
There is software-version 1.3 for Beomaster 7000, which is 2-way in Option 0. Perhaps this would be ideal in this setup ?
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Please pardon my ignorance, but surely, you can put it in option 2, then set your timer, then put it back in option 1 or 0. Andy T.
Ignace
- Moderator - NL
- Posts 2,749
I was under the impression that software version 1.3 was especially made for this situation ?
Peter
- Posts 9,572
Jandyt:Please pardon my ignorance, but surely, you can put it in option 2, then set your timer, then put it back in option 1 or 0. Andy T.
The problem with normal Option 0 is that the transceiver is switched off. Ignace has the correct suggestion though getting the software could be tricky. It should still be available but they seem to have emptied their stores recently.
Jandyt
- Posts 13,004
Ahh, sorry. I thought that it would still send a signal, just not receive one in option 0. Went out with my two sons last night and haven't yet recovered! Andy T.
hagan
- Joined on 05-19-2007
- Posts 128
Hi! What else does this s/w update do? Will there be any unwanted changes? I have s/w 1.1 in my Bm7000
regards
Ignace
- Moderator - NL
- Posts 2,749
As far as i remember, it makes sure that you can still use the 2-way Beolink 7000, even though the connected Beovision is 1-way. And it enables communication between Beolink 7000 and Beomaster 7000, even when the Option setting on Beomaster is set to 0 (infrared deactivated) I'm not 100% sure about this, as i use a Beomaster 6500 with Beolink 7000.
hagan
- Posts 128
Ignace:As far as i remember, it makes sure that you can still use the 2-way Beolink 7000, even though the connected Beovision is 1-way. And it enables communication between Beolink 7000 and Beomaster 7000, even when the Option setting on Beomaster is set to 0 (infrared deactivated) I'm not 100% sure about this, as i use a Beomaster 6500 with Beolink 7000.
Thanks! Sounds like a nice update for me. I could always put the old software back if I´m not satisfied. Any idea about the price for this update?
Peter
- Posts 9,572
Some nice person has sent me this! Service S/W - operation with BL 7000
Beomaster 7000, Type 234x
A service software, version 1.3, for Beomaster 7000 has now been
released. The service software makes it possible to use Beolink 7000 to
operate Beosystem 7000 in a set-up with BeoVision Avant.
When Beosystem 7000 is operated with Beolink 7000, the BeoLink
Converter will ensure the on/off function, volume adjustment, etc. in
BeoVision Avant. In this set-up Beolink 7000 is to be seen as hands-on
operation of Beosystem 7000.
Options:
BeoVision Avant must be in option 2, and Beomaster 7000 in option 0.
Beolink 7000 is configured for one-way video operation and two-ways
audio operation. The Beomaster 7000 will act as if it were in option 1
when two-ways operated with Beolink 7000
Possible operation via Beolink 7000:
Audio source operation, manual or timer programmed recording on audio
tape recorder, Mute as well as volume adjustment (the volume indication
on Beolink 7000 is different from the volume indication on BeoVision
Avant).
Impossible operation via Beolink 7000:
Timer light programming.
NOTE!
*Timer play programming, Timer on/off as well as Sound adjustment (e.g. balance, bass, etc.) is made via Avant using the Beo4.
*After installation and option programming or after mains drop-out, an
audio source must be selected by hands-on operation to obtain the
correct A/V set-up. This influences e.g. A/V RECORD.
*When timer programming the audio master, the Timer ON/OFF on the audio
master must be set to OFF. The Timer ON/OFF function is set on the TV.
*Audio sources are not switched off when changing to video source (because of possible users in link rooms).
*Balance, Bass, Treble and Loudness cannot be adjusted on the audio
master, operation is made with a remote control via Avant. Adjustment
will, however, affect a possible Link room. Volume adjusted from the
audio master, adjusts audio sources, but display indication on the
audio master may not be correct.
*Hands-on operation of audio recording of video sources is not possible (a remote control must be used).
*Recording on a possible A.TAPE 2 cannot be made by means of a remote control.
*Audio Timer record from program no. with 3 digits, e.g. the Satellite receiver in BeoVision Avant is not possible.
*In some cases it may be necessary to press stand by for several seconds to switch off a product.
Part no. for service software 1.3 (pos. 4IC2, coordinate 5A) is: 8342830.
Peter
- Posts 9,572
Unfortunately the Light programming doesn't work!!! Another good idea shot down!!
Ignace
- Moderator - NL
- Posts 2,749
So, this software version basically turns a 2-way Beolink 7000 into a 1-way machine regarding controlling video source. The same can be done by removing video sources from Beolink 7000 and adding again. What are the benefits / advantages of this software, i don't really see it.
Peter
- Posts 9,572
It means you can have the advantage of the speakers attached to the Avant but retain two way communication with the Beolink 7000. You will get source and track info and still be able to do some programming I suppose.
Jandyt
- Posts 13,004
Me neither! I think I have the best of both worlds with my setup. Avant in option 1 and 7000 in option 1. I can controll everything, I get a readout on my Beolink 7000, I can switch between my surround with labs on the Avant and my S120s on the 7000, and....... ....I can timer control my lights! Andy T.
Ignace
- Moderator - NL
- Posts 2,749
Same here, i also prefer to have "separate" Audio and Video masters / use AV-button to switch and of course timer control the lights, even program them from a Link-room
damatt
- Posts 190
Peter:Unfortunately the Light programming doesn't work!!! Another good idea shot down!!
My BM7000 is now in option 0, so I can't program it with the Beolink7000 in the main room, but it is still possible to program the lights in a link room. (connected with a MCL2AV) If I'm correct it would still be possible to turn on/off the lights with the BM7000 s/w1.3, you just can't program it in the main room. So the question really is: does the BM7000, with s/w1.3 in option 0, send out a signal to turn on/off the lights?
Peter
- Posts 9,572
Via MCL, yes, but not with the built in transceiver it would seem.
Page 1 of 1 (18 items)
