Latest post 01-28-2008 3:19 PM by PL212. 6 replies.
Page 1 of 1 (7 items)
  • 12-15-2007 8:49 AM
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Updating software chips in Beovisions
    Is it a reasonably straightforward job to update the software chips inside my MX7000 and LX 6000 Beovisions? What are the advantages?
    Dave
    Beowulf
  • 12-15-2007 9:49 AM In reply to
    Re: Updating software chips in Beovisions
    Most software changes are to correct small errors and allow newer equipment to be connected. Have you any thing that the TVs won't do? If not, I would leave well alone! Laughing I don't play around with TVs as the voltages inside can be lethal!
  • 01-27-2008 8:01 AM In reply to
    • Artimes
    • Not Ranked
    • Joined on 01-23-2008
    • Hengelo/Netherlands
    • Posts 6
    I've a Beovision Avant model 8111 which does not recognize the TV and most VRT functions. It's likely that the E-EProm is partly damaged because of flash.
    Does anyone know how to get a new programmed prom or a software update to burn a new prom?
  • 01-27-2008 8:28 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Artimes:
    These should be available from you dealer as a spare part.
    CraigSmile
  • 01-28-2008 2:14 PM In reply to
    • Artimes
    • Not Ranked
    • Posts 6
    Thanks Craig, in the meantime I've bought a defective avant in order to have an new prom. Next week I will collect the set.
  • 01-28-2008 3:07 PM In reply to
    • AT
    • Posts 187
    "Is it a reasonably straightforward job to update the software chips inside my MX7000 and LX 6000 Beovisions? "
    I think, it depends on the current version, but IMHO, it's not an easy question, because, for example, I can use only one version (and not the last one!) to use all the functions I need...
  • 01-28-2008 3:19 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    The 6000/7000 are relatively similar for the purposes of this question. The task involves dismounting a logic board and prising open a small tin that shields a certain area from interference. Within lies the EPROM to be replaced. There are special tools to remove this in an absolutely straight fashion, because the risk is that you will bend some of the many pins. But you can also use the blade of a flat screwdriver, gently, on either sides, until you rock it out.
    The real problem is that TVs contain dangerous voltages even days after they are unplugged, as well as the fact that the fragile CRT neck is in a vulnerable position during servicing.
