My Beolab speakers seem to work fine with B&O stereo through powerlink connections. I understood that these speakers can be connected to non-B&O stereos, so I connected the speaker's phono input to my Yamaha Amp and only one speaker works. I have moved the switch in the back of speakers to every position but no luck. Has anyone experienced similar problem and found an answer?
Would appreciate your advice!
