Latest post 12-26-2007 2:37 PM by himbi. 5 replies.
Page 1 of 1 (6 items)
  • 12-12-2007 9:46 AM
    • Ken
    • Not Ranked
    • Joined on 04-17-2007
    • Posts 60
    BEO4 in permanent "link" mode
    Hi all,
    I have a BV7 and a BL3500 located in two different room. The rooms are however in open connection. I have not had any problems operating the BV7 from a BEO4 in one of the rooms without the BL3500 reacting to the IR signal in the other room and the other way around. But after getting a BEO5 both units quite often react to the IR. I guess the BEO5 send much stronger IR the the BEO4, and thats nice but also can create problems.
    A way to aviod this cound be to set the BL3500 in "link" mode (option 6 i think), but then i have to press "Link" + "Radio" etc. when operation the BL3500. As i'm only using one specific BEO4 to operate the BL3500 it could be a solution if it's possible to set the BEO to permanet send "Link" mode signals. Any one knows if this is possible? and how?
    Regards,
    Ken
  • 12-12-2007 10:29 AM In reply to
    Re: BEO4 in permanent "link" mode
    Press Standby and List at the same time, then List untill Config appears then 2, 0, 0, 2
    The Beolab 3500 should be set to option 4.
    /Frank
  • 12-12-2007 10:49 AM In reply to
    It is certainly possible to have the Beo4 in permanent link mode provided your Beo5 provided your Beo4 software is at least at version 5.0 or later.
    When it is this mode it will send the "Link" command in front of every command with teh exception of pressing the "TEXT" button.
    To put the Beo4 in Link mode follow these steps:-
    Press STANDBY and LIST button at the same time
    Press up/down until the display shows "CONFIG"
    Press 2, 0, 0, 2 and then the display will show "LINK ON"
    Then press EXIT
    Use the same sequence to make the Beo4 show "LINK OFF" in the display
    NOTE: When the Beo4 is put into link-mode it will only be able to control TV's which are set to Option 4
    Regards Keith....
  • 12-12-2007 2:16 PM In reply to
    Hello Ken,
    I use an Infrared light dimming filter in my Beolab 3500.It was sold as filter for the old MCL eyes.There is a picture of it at the end of the MCL handbook. The serial number is 3370162. It should be still available, I bought mine last year.
    Regards Ralf
  • 12-13-2007 5:58 AM In reply to
    You can also purchase Beo4 reducers which fit on the end of the Beo4. You will see them in most B&O dealers Beo4's
    Regards Keith....
  • 12-26-2007 2:37 PM In reply to
    • himbi
    • Not Ranked
    • Joined on 04-23-2007
    • Muenchen
    • Posts 4
    And how about the TEXT function when the Beo4 is in "Link" modus.
    Or I cannot use anymore the videotext for the TV ???
    Chris
