Latest post 12-08-2007 6:50 AM by Peter. 9 replies.
Page 1 of 1 (10 items)
  • 12-07-2007 4:01 PM
    • David
    • Top 500 Contributor
    • Joined on 05-05-2007
    • England
    • Posts 128
    Beovision 3 in link room? Need help please.
    I have just purchased a Beovision 3 to put in our bedroom which replaces our Beovision 1 LS.
    I'm having trouble connecting it via Masterlink. We don't have an aerial at our house because we just use Sky. Anyway I cannot get the BV3 to link up via Masterlink.
    I have set the Beo4 to option 6. But still no picture. I can listen to music from the BS9000 but I cannot get any pictures.
    When I try and find the Link Frequency in Tuning it dosn't seem to be listed. I have a BV3 reference book but my tv menu seems to be different?
    Any help most welcome.
    Beolab 8000, Beolab 6000, Beolab 2, LG CX65, Beosystem 3, Beosound 9000, Beolab 3500
  • 12-07-2007 4:14 PM In reply to
    Re: Beovision 3 in link room? Need help please.
    You have run a co-axial cable as well as the ML cable?
  • 12-07-2007 4:36 PM In reply to
    If you get a black screen!  you need to set your scart connection none.
    What master TV do you have?
  • 12-07-2007 4:41 PM In reply to
    • David
    • England
    • Posts 128
    Hello Peter,
    Yes both ML and Coax are pluged in. These are the same wires that went to the BV1 so I know they work.
    I think it is something to do with me not being able to get into the link frequency menu.
  • 12-07-2007 4:42 PM In reply to
    • David
    • England
    • Posts 128
    The Stig - ver. 1.5:
    I have set all conections to none. The master tv is a Avant DVD.
  • 12-07-2007 4:59 PM In reply to
    Which BV3 is it? 28 or 32? Have you downloaded the Product Configuration Guide software? That will tell you how to tune the set in.
  • 12-07-2007 5:01 PM In reply to
    The PCG software can be found here.
  • 12-07-2007 5:08 PM In reply to
    • David
    • England
    • Posts 128
    Hi Peter,
    It is a 32"
    When I go to the tuning menu as decribed in the reference book the link frequency menu is not there?
    Thanks for th link, I will take a look.
  • 12-08-2007 4:36 AM In reply to
    • David
    • England
    • Posts 128
    Thanks for your help Peter. Have sorted it out now and very pleased.
    Cheers,
    David.
  • 12-08-2007 6:50 AM In reply to
    Delighted to hear it! The PCG is a great resource - unfortunately I cannot use it as it only works on Windows! Laughing
