Latest post 12-08-2007 7:17 AM by junkonhill. 4 replies.
Page 1 of 1 (5 items)
  • 12-07-2007 3:07 PM
    TT running slow
    My model 1700 B&O T.T. is running slow.  Here's my question; Should there be a belt guide on the motor spindle? The guides I have seen are brass and fairly thick. I think this would speed it to the proper rpm. The belt is currently running on the motor shaft itself. It seems a little loose to me. I haven't had this very long and bought a new belt, installed it, then checked the tt out. Any help on this would be appreciated.  Thanks,  Jim
  • 12-07-2007 5:10 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: TT running slow
    Welcome to Beoworld !
    Yes, there should be a brass pulley on the motor shaft, apprx 10mm in diameter. It's a press-fit but will also have been glued.
  • 12-07-2007 7:00 PM In reply to
    Re: TT running slow
    Thank you very much for this info. Now the next question; Do you have any idea where I might find one?  Thanks again,  Jim
  • 12-08-2007 3:14 AM In reply to
    • Dillen
    • Posts 5,008
    Re: TT running slow
    I have a little stock of good used parts but did you look inside the deck ?
  • 12-08-2007 7:17 AM In reply to
    Re: TT running slow
    Yes. I checked it out carefully.  Do you think you may have that part? I had just about given up hope. Please let me know.
    Thanks, Jim
