Latest post 12-07-2007 6:16 PM by Alex. 3 replies.
Page 1 of 1 (4 items)
  • 12-06-2007 5:05 PM
    BEOCENTRE AV5
    HI , I HAVE A BEOCENTRE AV5 IS IT POSSIBLE TO CONNECT AN MP3 PLAYER TO THIS AND IF SO CAN ANYBODY TELL ME HOW PLEASE. I BOUGHT A 3.5mm JACK TO 5 PIN DIN CABLE BUT IT DOSN'T FIT . WARREN
  • 12-06-2007 6:08 PM In reply to
    Re: BEOCENTRE AV5
    I suppose you have tried the Camcorder input?
    Another way if you have an iPod is to use an iTrip FM transmitter.
  • 12-07-2007 3:09 PM In reply to
    Re: BEOCENTRE AV5
    The iTrip transmitters are extremely poor.
    I would recommend going via the audio on a SCART port if you cannot find another way.
    Neil
  • 12-07-2007 6:16 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BEOCENTRE AV5
    Something like one of these and a suitable cable. Just stick the scart converter into 'IN' mode, and connect the minijack RCA plugs to the red & white connectors on the scart adapter and you'll be off!
    Will allow you to connect the video output from your iPod if it supports it as well! You'll need a Universal Dock though if you want to do this too.
     Weekly top artists:
