Latest post 03-15-2008 3:45 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 12-01-2007 7:41 PM
    • Jean
    • Not Ranked
    • Joined on 12-02-2007
    • Posts 2
    Confused [*-)] Beomaster 7000
    Hello to all,
    I have a Beomaster 7000  + Beogram CD 7000 + Beolink 7000 + Beolink 1000.  I moved to another country and tried to set up the equipment.  The problem : Everything is on but the Beolink 7000 displays a depressing "NO CONTACT" and the Beolink 1000 does not seem to work either.
    Please Help!!!
  • 12-02-2007 4:16 AM In reply to
    Re: Beomaster 7000
    On the Beolink 1000, with the system in stand by, try pressing SOUND 1 STORE. It may be that the transceiver is switched off.
  • 03-15-2008 11:14 AM In reply to
    • Jean
    • Not Ranked
    • Posts 2
    Re: Beomaster 7000
    I've been away for some time, but thank you Peter.   I tried your suggestion and it worked with the Beolink 1000.  Unfortunatly I have a very limited use of the Beolink 7000.  Only very basic functions are available and the remote doesn't seem to get information from the Beomaster 7000.  Any insights ?
    Filed under:
  • 03-15-2008 3:45 PM In reply to
    Re: Beomaster 7000
    I think the problem will possibly be that you need to reset the BL7000. You need to remove all components, then store: then add your components. The Beolink 7000 sets itself as two way by sending a signal and waiting for a response. If it gets none, it sets the component to one way. Do you know how to do this? If not, we can walk you through it.
