Latest post 12-04-2007 2:18 PM by The Stig - ver. 1.7. 6 replies.
Page 1 of 1 (7 items)
  • 12-01-2007 7:30 AM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    ADSL and beotalks
    Somehow the beotalk 1400 doesnt seem to work on the adsl ( dutch, experiabox ) outlet.
    Do all beotalks suffer this problem and what can be the cause. Im trying to look for a fix. I guess some better understanding of what is the difference between the original analogue and adsl signal. So hopefully some one can fill me in ?
    Maybe someone already has a fix and can share it?
    Regards
  • 12-01-2007 9:09 AM In reply to
    Re: ADSL and beotalks
    Have you fitted a filter? In the UK, all telephones need to have a filter between them and the initial phone socket.
  • 12-01-2007 10:27 AM In reply to
    • EOB
    • Posts 188
    This is the set up:
    Incoming phone line ( now adsl ) ->modem ( line in - dsl out / pstn out ) -> experia box has dsl in, experiabox has  pstn in -> experia has 2 seperate green phone sockets for 2 phones . 4 ethernet yellow sockets.
    Its not possible to use the original phone conection cords to put into the sockets. They will fit but they wont work. so the experia box has conection cord with green plugs ( same colour has the sockets. When you conect it with the green plugged cord the phone will work . So what im wondering is what exactly is different in the green plugged cord compared to the original (used with analogue signal cord)
  • 12-03-2007 5:24 PM In reply to
    Haw many phone's do you have connected?
  • 12-03-2007 6:50 PM In reply to
    • EOB
    • Posts 188
    Only the beotalk 1400
  • 12-03-2007 7:02 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    I have never heard of ADSL phone signal! I though ADSL was only used for internet...
  • 12-04-2007 2:18 PM In reply to
    Where are you from?
