Latest post 04-23-2007 10:28 AM by Craig. 4 replies.
Page 1 of 1 (5 items)
  • 04-23-2007 8:48 AM
    • jonnyb
    • Top 500 Contributor
    • Joined on 04-06-2007
    • London, UK
    • Posts 123
    Double DIN splitter - is there such a thing?
    I want to be able to use the AUX socket for Airtunes as well as routing the audio in from my TV. Trouble is there's only one AUX socket on my BS9000. Is there an adpator available that would enable me to put two sources into the one socket and switch between them?
    thanks in advance
    Filed under:
  • 04-23-2007 8:49 AM In reply to
    • Beobird
    • Top 150 Contributor
    • Joined on 04-19-2007
    • Netherlands
    • Posts 506
    • Gold Member
    Re: Double DIN splitter - is there such a thing?
    yes there is, and you can buy it on ebay. I bought one for my bc9500 as well
    We Can't Get Enough B&O Stuff...
  • 04-23-2007 9:03 AM In reply to
    • jonnyb
    • London, UK
    • Posts 123
    Found it. Bought it! Thanks for the quick reply Smile
  • 04-23-2007 10:09 AM In reply to
    • stevo4
    • Joined on 04-17-2007
    • Los Angeles
    • Posts 82
    i've been wondering the exact same thing for a while. Good to know.
    steve
  • 04-23-2007 10:28 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Had the same problem with my BS3000. Wanted to connect my PC and a Turntable. Got a B&O CD-TAPE  adaptor , works perfectly.
    CraigBig Smile
