Latest post 12-03-2007 11:53 AM by yachadm. 4 replies.
Page 1 of 1 (5 items)
  • 11-30-2007 7:06 AM
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Beomaster 3400 Headphone Jack
    Hi all
    On my Beomaster 3400, type 2802, the headphone jack (one of 2) has failed.
    I diassembled it to rebuild it - quite simple really, but metal fatigue over the years has taken its toll.
    The part #  is 7210023.
    It is a common part, having been used in many different Beomasters over the years.
    As it does not operate correctly, one channel's speaker output is interfered, and is low volume.
    1. Does someone have a NOS unit in stock?
    2. How would I bypass the jack, so that the speaker output returns to full volume?
    Kind Regards
    M Yachad
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 11-30-2007 12:54 PM In reply to
    Re: Beomaster 3400 Headphone Jack
    Is this a 6.35 jack socket with integral switches?
    B&O used some Japanese sockets,and also British (Cliff)Both types are still readily available here in the UK.
    Can you post a piccy?
  • 12-01-2007 1:48 PM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Re: Beomaster 3400 Headphone Socket
    Hi Solderon,
    Well, I guess opening up the BM3400 (AGAIN) is no big deal - I'm getting quite used to it now!
    I think you're probably right in it being a 1/4" (6.35mm) Cliff socket, but I couldn't find the exact model on their website.
    This one has 12 pins on the rear - 6 for each of the left and right channels, but B&O used only 3 pins for each channel.
    Pin allocations as follows (Left and Right Front Channels):
    4 - Green (from Power Amp & to 220 Ohm resistor)
    5 - Green White (To Speaker)
    6 - Headphone via 220 Ohm Resistor
    9 - Yellow (from Power Amp & to 220 Ohm resistor)
    8 - Yellow White (To Speaker)
    7 - Headphone via 220 Ohm Resistor
    Regards
    MY
  • 12-02-2007 11:57 AM In reply to
    great picture.It's the Jap socket actually,although they don't seem to use the switched contacts?
    Long time since I've seen a 3400!
    Socket readily available here:
    www.cpc.co.uk. part No CN01977
    Regards,
    Nick
  • 12-03-2007 11:53 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Hi Nick,
    I sent you a PM with an order.
    Did you get it?
    Regards
    MY
