I think that it is not so easy to mute the system by turning the wheel very fast. When I try to do so, it works only in about 60 percent of the cases.
Therefore I would like to know if I can create a softbutton to mute the speakers. Is there an ir code that I could use to send a mute command?
 Many thanks in advance for any helpul reply.
