Latest post 11-29-2007 9:57 PM by David. 11 replies.
Page 1 of 1 (12 items)
  • 11-29-2007 2:34 AM
    • David
    • Top 500 Contributor
    • Joined on 05-05-2007
    • England
    • Posts 128
    Mac Mini.Tiger or Leopard?
    I'm just about to purchase a Mac Mini to use as my media center so I can access my itunes with an itouch as described in Soundproof's detailed thread.
    Do you think I should go for a new machine with Leopard running or find a good used machine with Tiger installed?
    I have read somewhere that Leopard has a small amount of work needed.
    Cheers,
    David.
    Beolab 8000, Beolab 6000, Beolab 2, LG CX65, Beosystem 3, Beosound 9000, Beolab 3500
  • 11-29-2007 3:20 AM In reply to
    Re: Mac Mini.Tiger or Leopard?
    I have Leopard in all of my Macs now, and it's working very nicely.
  • 11-29-2007 4:52 AM In reply to
    • francis
    • Joined on 04-16-2007
    • Münster, Germany
    • Posts 108
    I am using my Mac mini for a year as a media center with Tiger, and I'm are very pleased with it. Last week I bought a new iMac (which is really a brilliant piece of technology, btw). The iMac was delivered with Leopard, so I decided to upgrade the Mini also.
    The installation was no problem at all and in general Leopard is running stable on my mini. All applications run and I have not yet discovered bugs. However, the performance is markably worse as compared to Tiger. For example it takes much longer to start applications or to switch between apps. As - once the app is running - the performance is acceptable it's ok for my purpose as a media center, only playing media and not really working with large files.
    The poor performance might be due to small memory (I only have 512 MB installled)
    If I wanted to work on media files with my Mini I would not switch to Leopard unless having better hardware.
    Francis
    |BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
  • 11-29-2007 5:17 AM In reply to
    @francis
    I'm quite certain it's your low RAM that is causing the slowdowns, Leopard does want space to move. I have 2GB in my computers, and have not noticed any slowdowns.
  • 11-29-2007 6:00 AM In reply to
    • David
    • England
    • Posts 128
    Thanks for the replies.I will go for a new machine then with Leopard installed.
  • 11-29-2007 12:23 PM In reply to
    • francis
    • Münster, Germany
    • Posts 108
    @soundproof
    I agree and think I will have to expand my Mini's RAM. Do you think it's imperative to have 2 GB or will one GB be sufficient for my purpose?
  • 11-29-2007 12:38 PM In reply to
    • bwaje
    • Not Ranked
    • Joined on 11-22-2007
    • Paris - France
    • Posts 38
    The best way to improve the mac mini is :
    - putting at least 1 gig of mem
    - changing the hard disk for a 7200 rpm
    Any mac mini (even first G4) can support Leopard, just search for Apple minimum config for Leopard.
    b&otien
  • 11-29-2007 1:13 PM In reply to
    • David
    • England
    • Posts 128
    Have just found out that Airport Extreme will work with a PC not just a Mac. With this in mind would an itouch or iphone be able to access my itunes on my PC via the Airport Extreme? Would be great if this works because I wouldn't have to buy a Mac Mini. Has anyone ever tried this?
    Cheers,
    David.
  • 11-29-2007 2:12 PM In reply to
    • bwaje
    • Not Ranked
    • Paris - France
    • Posts 38
    The iPhone seems windows-compatible, look here : http://www.apple.com/fr/iphone/specs.html
    b&otien
  • 11-29-2007 3:06 PM In reply to
    • David
    • England
    • Posts 128
    Thanks I will do more investigating.
  • 11-29-2007 3:21 PM In reply to
    David:
    Cheers,
    David.
    Remote Buddy is Mac only, and you'll need to be able to run that to get that functionality with an iPod Touch.
  • 11-29-2007 9:57 PM In reply to
    • David
    • England
    • Posts 128
    Thanks Soundproof. ;-)
