        1st March February 2012
	    Latest post 12-02-2010 6:27 PM by  Gunfai. 22 replies.
									        Peter
								                - Joined on 02-12-2007
								                - Posts 9,572
										    Re: Use of Beomaster 7000 with 5500 components
										    It should be. The AV7000 actually stopped the two way communication working as it took over the master functions. A Beolink 1000 would be ideal. Although the AV7000 is a US model and I cannot pretend to have experience of it, I have had both 5500 and 7000 systems which can use the same remote. Get one with the Beolink sticker on though.
									        meling0017
								                - Joined on 11-18-2007
								                - Stavanger, Norway
								                - Posts 18
										    Thanks. What do you mean with getting one with the beolink sticker. I plan to exchange my Beomaster 5500 with the A/V 7000 and also use a power converter to handle the 110 V. Henry
									        Ignace
								                - Joined on 03-30-2007
								                - Moderator - NL
								                - Posts 2,749
										    How about the Beogram 5500 ?
									        meling0017
								                - Stavanger, Norway
								                - Posts 18
										    What do you mean? If I want to sell it or use it with the A/V 7000? I will use it if I can.
									        ridax
								                - Joined on 04-16-2007
								                - Posts 44
										    He probably means that a Beogram 5500 record player won't work with the Beomaster 7000, which is correct.
									        Ignace
								                - Moderator - NL
								                - Posts 2,749
										      meling0017:What do you mean? If I want to sell it or use it with the A/V 7000? I will use it if I can.
 Whoops, sorry     I meant regarding connecting to BM7000 (RIAA amplifier yes-no)
									        Ignace
								                - Moderator - NL
								                - Posts 2,749
										      ridax:He probably means that a Beogram 5500 record player won't work with the Beomaster 7000, which is correct.
 I almost connected my Beogram 6500 to a Beomaster 5500 , but just as i was about to connect it, a voice inside me told me not to do that
									        meling0017
								                - Stavanger, Norway
								                - Posts 18
										    Thanks but I am a little confused. Is the conclusion that I can not use a A/V 7000 together with Beogram 5500? What is the problem actually. Is the same problem present for the CD and tape recorder from the 5500 series? Is the conclusion that I should not use A/V 7000 with 5500 components.
									        PL212
								                - Joined on 02-14-2007
								                - Moderator - Seattle
								                - Posts 318
										    Holdon everyone -- if the question is whether you can replace a BeoMaster of any kind with an AV7000, the answer is no: the AV7000 is not an audio master and has no connections for extra audio equipment such as the CD, Tape and Phono.  It may look similar to a BeoMaster 7000, but it's really not!
									        beo-ap
								                - Posts 231
										      PL212:Holdon everyone -- if the question is whether you can replace a BeoMaster of any kind with an AV7000, the answer is no: the AV7000 is not an audio master and has no connections for extra audio equipment such as the CD, Tape and Phono.  It may look similar to a BeoMaster 7000, but it's really not!
 Agreed AV7000 and BM7000 are two completely different things. BM7000 is a receiver intended for audio and includes a tuner as well as connections for external audio sources such as CD, Tape, and AUX.   AV7000 is a relatively simple surround sound processor with some AV connections. For example, it has an amp for center channel active speakers need not apply), PL connections for rear channels, and inputs/switching for some video sources. It also had a very limited ability to convert BL1000 commands to standard IR to allow control of video sources and power on TV.  AV7000 was a US only product and has been off the market for many years now. In some way it could described as an early ancestor of the current BeoSystem 3.
									        rabble
								                - Joined on 07-13-2007
								                - Switzerland
								                - Posts 75
										    I have a beosystem 7000 and would like to somehow add surround to it and at the ssme time keep the look of the system.  I have a chance to buy an AV7000; can I someohow ty this in to  my existing system?   Andrew
									        Peter
								                - Posts 9,572
										    Possible - yes. Sensible - no! It looks like the perfect solution but: 1. Except for a couple of prototypes, it is a US system and uses NTSC. 2. It disables the two way communication with the BL7000 so you will need to use a Beolink 1000. 3. Dolby Pro-Logic only.
									        Russ
								                - Joined on 05-07-2007
								                - Washington, DC  USA
								                - Posts 641
										      meling0017:Thanks. What do you mean with getting one with the beolink sticker. I plan to exchange my Beomaster 5500 with the A/V 7000 and also use a power converter to handle the 110 V. Henry
   Whoa everyone!!     The AV-7000 is not exchanged for the BeoMaster...It is added into the system alongside the BeoMaster.   All of the speakers are then connected to the AV-7000, the AV devices (V. Tape, CDV, SAT/STB) are connected to the AV-7000, but all of the audio devices remain connected to the BeoMaster, similar to the manner in which an MX and a BeoMaster 5500 would be connected, or in deed a BeoSystem 1, 2, or 3.   Henry, you have to keep the BM-5500.   Russ
									    We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA  USA
									        rabble
								                - Switzerland
								                - Posts 75
										    Since I only have the beolink 1000 anyways thsi will not be a probllem.   At the moment I have no suround system at all, so when you say Pro-Logic only is this really an issue? Why is NTSC an issue, there will only be an audio signal going to the unit? When I lsiten to music only, will there be any loss of sound quality in stereo mode compared to using the BM 7000 only?   Andrew
									        rabble
								                - Switzerland
								                - Posts 75
										    Hi, I finally won an AV7000 on ebay.  I am hoping that I will be able to connect my beomaster 7000 to the unit so that I can keep my existing system and add suround sound to it. I plan on using my beovox 5000 / beovox 2500 as the front speakers (hopefully I won't need active units?), and now need to find some units for the rears and centre. As the av7000 will probably come without a manual, can you please let me know how I will need to hook up everything? Thanks for the help    Andrew
									        Peter
								                - Posts 9,572
										    Ideal time to join as a silver or gold member! The user and reference manuals are both on site!
									        PL212
								                - Posts 318
										    The AV7000 is Powerlink for the front and rear speakers so you will need at least a BeoLink Passive to power the BeoVox 5000.  I've never heard of BeoVox 2500, what are those?  I assume you are interested in Video sources for surround sound?
									        rabble
								                - Switzerland
								                - Posts 75
										    I was hoping to be able to use the amplifier of the beomaster 7000 to power the front speakers via the AV 7000, and then the centre and rear speakers to be powered by the av7000.  All I am lookin for is a method of adding a simple suround sound system to my beosystem 7000 as it would be a shame to get rid of such a wonderful audio system. No other controls will be required, I do have a beolink 1000 that should be able to control the complete audio system. Have I misunderstood what the AV7000 can do?   Andrew
									        PL212
								                - Posts 318
										    Unfortunately the system will work so that all of the speakers need to be connected to the AV7000.  The BM7000 connects via a PowerLink and DataLink cable, but its amplifier is not utilized. The AV7000 has a built-in amplifier for the center channel only...
									        Gunfai
								                - Joined on 09-26-2008
								                - Posts 13
										      Peter :
Two-way actually works in Beosystem 7000 with software 1.3 in the Beomaster 7000. The NTSC part is not needed for surround processing.
        Page 1 of 1 (23 items)
