Latest post 11-27-2007 11:32 PM by beo-ap. 13 replies.
Page 1 of 1 (14 items)
  • 11-27-2007 11:23 AM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    LC2 and energy saving light bulbs
    Just tried using my LC2 with an enargy saving light bulb. In the manual it does say this is possible, but you cannot dim the bulb. Well I get nothing at all. Not even the basic On/Off function. Any idea what the problem could be.
    CraigSmile
  • 11-27-2007 12:10 PM In reply to
    Re: LC2 and energy saving light bulbs
    hi  craig,
    have you had it working before?
    have you checked the internal fuse?
    hope this helps jay
    jason
  • 11-27-2007 12:12 PM In reply to
    • Craig
    • Posts 4,855
    Hi Jay, it works fine with normal bulbs. Just not when I use an Energy Saving one. Tested the bulb and it works so it is not down to a faulty bulb either.
    CraigSmile
  • 11-27-2007 12:50 PM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    Craig:
    CraigSmile
    If you alter the settings for LC2 to switch just on and off the energy saver will work. You can now but dimmerable ones and they work perfectly
  • 11-27-2007 1:14 PM In reply to
    OSRAM have just released an energy saving bulb that can be dimmed. Check the net for that.
  • 11-27-2007 2:43 PM In reply to
    Only a few types of energy saving bulbs will work.
    Regards Keith....
  • 11-27-2007 2:56 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Craig,
    I might be stating the obvious but you have to program it to accept low energy bulbs
    Hold finger on the dome whilst pressing
    Light,GOTO,0,Store,3
    HTH, Smile
    Poor me, never win owt!
  • 11-27-2007 3:28 PM In reply to
    • Calvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • London
    • Posts 233
    As for economy, I'd have thought there's a fairly reasonable thought that if you can afford a £10k stereo, you can afford a bit more electricity. It's an argument for the tight-fisted
    If, however, you want them to save the environment, then I must admit that I think you're completely deluding yourself.  Firstly, I would advse anyone to search on the net for 'global warming lies' or the like, to therefore read both sides of the argument, and to make up their own minds about it.  Even if you do believe in man-made global warming, there's far better ways to trim CO2 emissions than to save 40W on a lightbulb.
    Did you know that to produce 1 tonne of aluminium (the B&O material of choice) it takes half a tonne of carbon anode plus around 10 tonnes of CO2 generated electricity, plus quite a few more to fabricate a component and ship it?  If you take the price of $30 per tonne of CO2, as the next set of emissions certificates are likely to cost in the EU, then you're probably far better off never buying B&O ever again than switching to energy saving lighbulbs.
    Plus they look terrible
    Plus I actually work for a mining & metals consultancy, I know what I'm talking about
  • 11-27-2007 4:04 PM In reply to
    There are other reasons for using energy saving bulbs. They don't emit as much heat as regular bulbs.  This is very important if you live in the tropics.
  • 11-27-2007 7:27 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    If you choose not to buy any B&O well, then someone else will simply get it, the aluminium will still be produced and you'll miss out!
    Every little bit counts, and everyone using energy saving bulbs is a small step, but it is still a step. It's all about everyones attitude to using less energy. Otherwise if everyone was as skeptical as that, then we would be churning out even more carbon emissions wouldn't we.
  • 11-27-2007 7:31 PM In reply to
    • Craig
    • Posts 4,855
    Thanks for the replies, I will let you know how I get on.
    CraigSmile
  • 11-27-2007 7:39 PM In reply to
    Well this is all news to me! Thanks for starting this post because I wanted to buy an LC2 but was told it does not work at all with energy saving light bulbs which is what is used in my light. Guess I am on the look out for one again!
    Cheers to you all.
    Simon.
    PS Lee, I am in the market for an LC2 again if you still have one. Will PM you as well in case you miss this.
    "We can rebuild him. We have the technology." 7-40, 7-2, 9000, BS3, BC2, LC2, BC6000, Beo5
  • 11-27-2007 10:26 PM In reply to
    Dear All:
    Was this item released in the USA?
    Dario
    When I hear music, I fear no danger. I see no foe... Thoreau
  • 11-27-2007 11:32 PM In reply to
    No, we never got the LC2 in the US. We only got the LC1. I'll be putting mine up for sale soon. Don't use it any more as Lintronic with X10 does all I need and more.
