Latest post 11-26-2007 5:54 PM by Alex. 7 replies.
Page 1 of 1 (8 items)
  • 11-26-2007 12:42 PM
    New BeoVision 4´s
    Hi all
    Just thought i would share some information about the new BV4 series comming up in the near future. (Actualy do not know if it will be called BV4, but is is supposed to look just like it) Anyway, a cool feature will be a small camera that slides out in the top and occasionly meassures the black in the picture and adjusts it.
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 11-26-2007 1:24 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Southern CA
    • Posts 137
    Re: New BeoVision 4´s
    Oops double post
    -Alex
    • Alex
    • Southern CA
    • Posts 137
    Yeah its the new line of BeoVision 4s. The Camera will measure the color temperature and calibrate the panel every so often. Pretty cool stuff if you ask me!
    -Alex
  • 11-26-2007 1:38 PM In reply to
    Any idea when it will be available?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 11-26-2007 1:44 PM In reply to
    • Alex
    • Southern CA
    • Posts 137
    they say Q1 of 08 but you know B&O haha
    -Alex
  • 11-26-2007 3:47 PM In reply to
    what means Q1 ? Do you think there will be used panasonic panels ?
  • 11-26-2007 4:05 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Q1 means Quarter 1, therefore Quarter 1 2008 i.e. sometime from January to End of March.
  • 11-26-2007 5:54 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    Smart, I wonder what the new panels will be too...
     Weekly top artists:
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
