Latest post 11-27-2007 4:56 AM by Santiago. 8 replies.
Page 1 of 1 (9 items)
  • 11-25-2007 4:49 PM
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Beo5 Audio Command
    Hi
    Does anyone know what command i have to use to switch between diferent languages in a TV program?
    I used Sound in Beo4, but i tried Sound in Beo5 and it is used to change between speakers system.
    Quim
    Quim
  • 11-25-2007 6:48 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beo5 Audio Command
    Hola, Quim de Tarragona.
    I'm not sure, but I think it may depend on which TV and/or set top box you are using.
    Andy T.
    Poor me, never win owt!
  • 11-25-2007 7:16 PM In reply to
    Andy is right Quim,
    Beo5 "Sound" command works fine for me, and I have no problems to switch the tv audio language in the avant.
    To change among the different speaker modes I use the beo5 "Speaker..." command.
    Santiago
  • 11-26-2007 1:36 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Thanks, Andy and Santiago
    I use a BV7 Mk I, with STB controller, but i don't talk about to change languages of any DVB, just of analogic TV. When i click Sound, TV asks me about to change Speakers mode. If i do the same with my Beo4, TV asks me to change between Mono, mono-1, estereo, etc.
    I will do more tests.
    Quim
    Quim
  • 11-26-2007 6:54 AM In reply to
    Quim43:
    i don't talk about to change languages of any DVB, just of analogue TV.
    Hello Quim,
    in my case (Beo5+avant) the "sound" command works well changing between languages with analogue TV, hope this help.
    Good luck.
    Santiago
  • 11-26-2007 1:45 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Hi
    It's fixed. It was a mistake due to language in my Beo5. In my Beo4, i have to send Sound to change languages, so i supposed it was the same with the Beo5, but the Beo5 IR Command: "Sound" changes Speakers Mode. The IR Command to change languages on TV with Beo5 is "Turn".
    I don't know if i explained it correctly, but, at least, now it works fine.
    Quim
    Quim
  • 11-26-2007 3:39 PM In reply to
    That's very curious !!! Huh?
    I think all it's due you have a BV7 and I have an Avant, because in my case Beo5 works exactly as my Beo4:
    Beo5 "Sound" command change languages in tv dual channels, and "Speaker" the speaker mode...
    In my beo5 the "Turn" command doesn't exist ! Unsure
    Anyway, the only important thing is that now everything works for you Quim... Yes -  thumbs up
    Regards.
    Santiago
  • 11-27-2007 1:33 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Hi Santiago
    I knew I didn't explain well. Sound command is to change languages in a dual channel, the same as you, I meant IR Command is Turn, when you are in the Edit Tab in the configuration software, something like this: 0:000:TV:TURN.
    Hope now it's more clear.
    Regards
    Quim
    Quim
  • 11-27-2007 4:56 AM In reply to
    Oh yes!
    Now I've understood perfectly well... and you're right Quim.
    Enjoy!
    Santiago
