Latest post 11-24-2007 4:05 PM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 11-24-2007 3:41 PM
    BC 9500 LINE IN/OUT plug
    Hi, if i'm wanting to run a passive equalizer that has RCA plugs only.... on a BC 9500....I pull out the plastic plug...what adapter goes in to convert to RCA.?? Is that a simple DIN 4 plug converter for ins and outs??
    THEN....do i need to press any buttons...or will that now equalize all the sound?  ie, is that plug the "loop" from the pre-amp section just before the amp??
    THanks, K
  • 11-24-2007 4:05 PM In reply to
    Re: BC 9500 LINE IN/OUT plug
    The plug is indeed a simple straight though connector.
    Unplug it and the circuit is interupted prior to the pre-amp.
    The wiring to the plug is shown on page 2-16 of the service manual on site.
    Regards Graham
