Latest post 11-24-2007 2:59 PM by The Stig - ver. 1.7. 1 replies.
Page 1 of 1 (2 items)
  • 11-24-2007 2:35 PM
    AVANT DSS speaker setup for BL 5s
    Can anyone tell me which setting I should be using on my AVANT for the FRONT surround speakers.  Menu 'SOUND' > 'SPEAKERS' options say 'Type-A'  or 'Type-B'   Changing between the two options seems to decrease the outpout level slightly (with Type B).  The manual only refers to speaker types BL 8000 - BL Penta, BL 6000s etc  (it's a 1999 AVANT).   I'm using BL 5s and they work fine with both options on the AVANT.  Just want to make sure that there's no danger of having the 'wrong' setting (output level) from the TV into the BL 5s...  Don't want to break them if I can help it.  There's options to change the input sensitivity on the BL5s too but I'm not messing around with that, they're loud enough thanks.
     Jack
    Jack
    BV10(40) BV8-32, BV3-32, MX7000, DVD1, HDR1, V8000
    Beomedia-1, BS9000, BC7002, BC2300, BS5500, BM6500, BGCD6500, BM1900-2
    BL5, BL8000, BL6000, BL Penta3, BL3500
    Beovox MC120.2, 3000 Panels, CX50s, C75s, AND LOTS WIRES, BOOkS, MAGS n BITS (ebay sales: beo-store-uk)
  • 11-24-2007 2:59 PM In reply to
    Re: AVANT DSS speaker setup for BL 5s
    Use the same setting as penta... A and B ref. to haw mush bass the TV sends to the speaker.
