Latest post 12-07-2007 6:22 AM by meekablue. 4 replies.
Page 1 of 1 (5 items)
  • 11-24-2007 5:41 AM
    Beolab 1700
    My Beolab 1700 Amplifier is (hopefully) being repaired but just in case not possible I have the chance of a Tuner/Amp 2300 is this a good/better  option - has anyone had any problems with theirs? Thank you for any input available.  meekablue.
  • 11-24-2007 6:33 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beolab 1700
    A strange beast and qute rare by all accounts. It was basically a cross between the beomasters 1900 & 2400 and only released in the UK if I remember correctly. It doesn't have remote control though so my personal choice for ease of use would be the 2400, although I would own one myself simply for its rarity value. Nice amp though and a design that I particularly like, but as with all pieces from this era it would benefit from new capicitors. I also believe the lamps may need replacing at some point in the future.
    Capacitor & lamp kits are available from Beoworld member Dillen (Martin).
    Chris.
  • 11-24-2007 7:06 AM In reply to
    Re: Beolab 1700
    I have complete confidence that Tim will fix this for you! He says he already has the relevant transistors waiting! I would be pretty sure that Chris is correct and the 2300 could well need repair itself and it is quite a bit more complex than the Beolab 1700.
  • 11-24-2007 3:47 PM In reply to
    Re: Beolab 1700
    Thank you Peter really appreciated.  Hopefully Tim has my poor old Beolab by now it is supposed to be sent direct to him - well .... fingers crossed.  Jane
  • 12-07-2007 6:22 AM In reply to
    Re: Beolab 1700
    Hello Peter - have sent you a private message - re Beolab - thank you Jane
