Latest post 11-24-2007 4:11 AM by ®. 5 replies.
Page 1 of 1 (6 items)
  • 11-23-2007 2:39 PM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Avant DVD noise
    Just tried watching a DVD and the disk failed to load. More worrying was the noise the player made (crackles/scratching/creaking). All other DVD's play fine with no noise and the suspect DVD plays in my PC with no problems??
  • 11-23-2007 2:44 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Avant DVD noise
    Had the same problem with my Phillips DVD Recorder. Some discs just will not play, when it rtries it sounds as though it is destroying the disc. Stick them in the X-box or the £30 DVD player in the bedroom and they play no problem. Not sure why this happens though.
    CraigSmile
  • 11-23-2007 6:34 PM In reply to
    Re: Avant DVD noise
    It's because the DVD disk is out of spec. return the DVD and go to another store and bay it.
  • 11-24-2007 2:25 AM In reply to
    • UK
    • Posts 970
    Re: Avant DVD noise
    Thanks, but whats making the noise?
  • 11-24-2007 3:40 AM In reply to
    • 9 LEE
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Avant DVD noise
    Is the DVD warped ?
    Only a thought, but had a couple of warped ones that sound like a disc cutter when the Avant has tried to play them!!
    Lee
  • 11-24-2007 4:11 AM In reply to
    • UK
    • Posts 970
    Re: Avant DVD noise
    No it sits flat on my desk. Its a Tesco's online DVD Rental disk and I've had problem disks from them before. The last one froze three quarters the way through The Last King Of Scotland. Very annoying.
