Latest post 12-25-2007 4:38 AM by Doc. 6 replies.
Page 1 of 1 (7 items)
  • 11-23-2007 9:11 AM
    Beo 5 and only one big Picture
    Hella again.
    Is it possible to use a big picture on the whole screen? I know there are many buttons, but i must be possible. Or not?
    Thanks for your ideas
    Baolu
  • 11-23-2007 10:31 AM In reply to
    Re: Beo 5 and only one big Picture
    Hi Baolu,
    Yes it is possible.
    I have a fairly large B&O logo on the 'Zones' screen, as there are only 3 buttons on this screen so there's nothing to cover up by mistake.
    Just create a button and link the logo to it.
    However, it can be a little hit or miss sometimes until you manage to get it to display.  Adjusting the image size a little seems to work, though there seems to be little logic to whether or not it works at the moment.
    Cheers,
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
  • 11-23-2007 12:58 PM In reply to
    Hi Martin,
    thanks for your answer. I tried it, but it doesnt work. On the Zones Screen are always 4x3 buttons . It makes no differenz if the bmp is    300xYYY or 3000 x YYY.
    Its only the little Pic on the button.
    Do you have any ideas?
    Cheers , Baolu
  • 11-24-2007 5:19 PM In reply to
    Make it on the next screen instead as you only want one picture there is no need to use the zone screen.
  • 12-24-2007 10:55 AM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Can you then delete the first Zones screen?
  • 12-24-2007 11:09 AM In reply to
    You cannot delete the first zones screen because it is effectively the index or the top of the tree.
    What you can do, however, is put buttons which are common to many rooms on the zone page
    Regards Keith....
  • 12-25-2007 4:38 AM In reply to
    • Doc
    • Posts 585
    Stig,
    With "next screen" you mean create a next zone? When I tried, still got a small button (although it was 218 x 190 pixels).
    What do I do wrong?!
