Hi All! I'm posting regarding a BeoCenter 2500 with some door issues (the doors do not close all the way).
==============Quick history==============
A coworker asked if I could fix his BeoCenter - he had it in storage for about 5 years, and the doors would automatically open when it was turned on, never closing unless manually pushed shut. After reading about it on the web, I thought either an IR LED or IR receiver burnt out. It was actually much simpler -> dust had collected behind the dark plastic panels to the left and right of the CD/tape mechanism.
Long story short, I disassembled the back case, bottom surround, and two dark plastic covers. I cleaned ALL the grease and grit off the gear mechanism and lightly greased it with general purpose lithium grease. Since they are plastic gears, I assumed a little amount of lithium grease wouldn't hurt. They made a lot of noise when they operated -> there were what looked like grains of sand stuck between 3 gear teeth. I cleaned the plastic panels, dusted the metal areas on the inside.
Anyhow, the door mechanism operates properly when the doors are off. When the glass is on they open ok, but do not close all the way. I would say they close about 1/3 of the way.
1) I know I did not get any grease on the motor pulley
2) I'm not 100% sure the doors closed OK on their own before, since the doors had to be pushed shut manually
3) Should I grease the rails? There is no apparent blockage. There are some patches on the rails that look raised.
4) Looking at the front, and mounting only one door at a time, the door closes when the right door is the only one mounted. When the left door is the only one mounted, the mechanism stops about 1/3 of the way closed.
Any ideas? Could the door wire be stretched? Should I try taking apart the wire-pully assembly, and reassembling it? Should I replace the motor-pulley drive belt?
Thanks!
John
