Latest post 11-21-2007 8:41 PM by auric. 5 replies.
Page 1 of 1 (6 items)
  • 11-21-2007 3:01 PM
    Beosystem 2500 Connection
    I am trying to connect the stereo system to a wireless outdoor speaker. The problem is the aux output connection. Any outdoor speakers i can locate require an audio output connection. Is there an adapter or a way around this problem. I have little technical prowess so a detailed description would be greatly appreciated.
  • 11-21-2007 3:39 PM In reply to
    Re: Beosystem 2500 Connection
    Try getting the sound signal from the powerlink instead... the volume is variable...
  • 11-21-2007 3:43 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Firstly welcome to Beoworld. What type of connections are on the Speaker? If you can give us a make/model of something you have in mind. Then that may also help.
    CraigSmile
  • 11-21-2007 7:47 PM In reply to
    Thank you for the quick reply. The speaker I am considering is a wireless Aucoustic Research AW811. The transmitter has a single pin audio in connection. The techies at Acoustic Research had no wireless speakers compatible with the aux connection on my Beosystem 2500 and offered no suggestions for adaptation. Spoke to technical service rep at Parts Express, on line store, and he had no products compatible nor could he suggest an adapter. My prior Recoton Wireless transmitter had RCA connectors to the transmitter and worked well for years.
  • 11-21-2007 7:48 PM In reply to
    I have no idea how to do that!
  • 11-21-2007 8:41 PM In reply to
    Try taking the audio out of the head phone jack?
