Latest post 11-22-2007 3:33 PM by Peter. 8 replies.
Page 1 of 1 (9 items)
  • 11-21-2007 7:22 AM
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Slow 'fast forward' on Beocenter 1400
     Hello!
    I have a Becenter 1400 (which I bought for 30 euros!). It's otherwise completely working (I did changed some lamps) but there seems to be some small troubles. Sometimes when playing a tape there is some "metallic" noise, that sounds like there were something touching the flywheel (sometimes it slows the playback speed down) and it's released by swithcing pause on and off.
    Also I would like to know if the tape deck has a belt-driven mechanism or not. The reason is that the fast forward is very slow and usually stops after some twenty seconds. If it has no belt I would like to know how should I try to fix it. It might be just dirt in the rollers, in that case the question is should I open the case from the top or from the bottom. The rewind is fine.
    Thanks in advance!
    Bang & Olufsen - The art of controlling sound, picture and light
  • 11-21-2007 9:41 AM In reply to
    Re: Slow 'fast forward' on Beocenter 1400
    I'll see if I have that manual tonight.
  • 11-22-2007 11:10 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    It will probably need cleaning and lubricating of the whole mechanism, motor etc.
    It's belt driven, one belt (in stock if you need).
  • 11-22-2007 11:16 AM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    Dillen:
     Thanks!
    I'll try to clean it first. It most likely helps as the previous owner has used the recorder a lot so it might be good idea to take a look.  From which way should I open it, the top or the bottom? Or which way it's easier? I'll try cleaning first, then replace the belt if necessary
  • 11-22-2007 11:44 AM In reply to
    I would take the top off. I have found the service manual - quite detailed and a fair amount of detail about the tape mechanism. You will need to join as a silver or gold member to access it. Let me know if you plan to join as I will make it a priority to scan it! It will take an evening!
  • 11-22-2007 11:54 AM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    Peter:
    I'll have a look of the recorder later this evening. Just to check how it looks like. I have opened the cover when changed the lamps but prefered not to touch the tape part. :)
    I have been waiting for a strong reason to join as a silver or gold member, and I guess this would be one. I'll check it out. So I guess I would be joining soon, so the manual would be needed. No hurry! Thanks!
  • 11-22-2007 12:54 PM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    Ok, I joined as a silver member. :)
    I guess it will pay itself back, I already had a look in the manuals section and I was so excited! Looks great.
  • 11-22-2007 1:46 PM In reply to
    Looks like I have found my job for tonight!!
  • 11-22-2007 3:33 PM In reply to
    One 53 page service manual, in colour where required, now on site! Look here!
