Latest post 11-20-2007 11:38 AM by MartinW. 1 replies.
Page 1 of 1 (2 items)
  • 11-20-2007 1:37 AM
    • GANGO
    • Not Ranked
    • Joined on 04-17-2007
    • italy
    • Posts 48
    beo5, sky+- how to pause?
    i've got the sky+ decoder connected to the bv9 and everything works fine with the beo5 except one thing:
    i don't know how to pause the current program. on the original remote there was the   II    button, but i can't find any button or sequence to press to have the same function. also my dealer doesn't know how to program it.
    if i press the  STOP button the HDR unit of the bv9 gets in function and this is not what i want. is there  any possibilty to create a button on the screen and what is the code for it? so i can help my poor dealer Yes -  thumbs up
    grazie
    gango
  • 11-20-2007 11:38 AM In reply to
    Re: beo5, sky+- how to pause?
    Hi there,
     I had similar problems with mine and discussed it in the forum here: http://forum.beoworld.org/forums/thread/60052.aspx
    I posted all the code that fixed it, so it may be of use for you to take a look.
    Thanks,
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
