Latest post 12-05-2007 10:08 PM by Ilikehifi. 5 replies.
Page 1 of 1 (6 items)
  • 11-19-2007 2:14 PM
    • Calvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • London
    • Posts 233
    DIY Proector Bulb
    Well, not strictly B&O related but then I'm sure a lot of users have projectors.
    Basically, my projector gave up the ghost at the weekend, somehting I'd half expected it to do for a while as I bought it 2nd hand quite cheap due to the age of the bulb.  Anyway, new ones on the net are about £220 and so it leaves me with a fairly expensive scenario, at least in so much as i really need a new bulb and a spar ebulb for when that one goes at a bad time.
    However, I was wondering if there's aything to stop me using a normal light bulb? I'm thinking that the spotlight bulbs in my kitchen are very bright when you have them up full and I was thinking of getting one and wiring it up.  The "bulb" unit for the projector is more like a plastic cradle that holds both the bulb and the wiring in place. I could easily justput a regular bulb in there.
    As far as I can see, the only issues are the brightness I'd get, and the risk of a fire if I did a bad job. On the basis that I did electrical engineering, I don't see the later as being a risk; after all, it's not as if I'd do anything stupid like use a soldering iron for mains voltage
  • 11-19-2007 3:51 PM In reply to
    • cozza
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    Re: DIY Proector Bulb
    Although some of the first video projectors used conventional filament lamps, yours will have a discharge or metal halide type of lamp. The price of the replacement lamp you stated would be about right for an discharge lamp.
     It's not a straightfoward swap to put a halogen lamp in a projector. The power supply for the discharge lamp is current regulated, between 25 to 140 volts depending on the lamp. The lamp igniter produces a high voltage ignition pulse which would cause damage to the old lamp socket if no arc lamp is installed, and would blow up if connected across a kitchen spotlight bulb.
    Halogen lamps produce much more infrared than a metal halide lamp of comparable size, and this will damage the polarising filters in the optical assembly.
    Obtaining even illumination of the whole picture is more difficult than you may think. The colour temperature of the lamps is different, incandescent are yellow, and arc lamps are more like daylight, this will affect the picture.
    Lastly the projector electonics monitors the lamp status, and shuts down if there is an error.
    It's not an option unfortunately. Nice idea, but you may ruin a perfectly good projector trying.
  • 11-19-2007 4:18 PM In reply to
    Depending on the projector you can buy the ''raw' lamp and put it in the fixture. let us know which projector you have and maybe somebody can help.
  • 11-20-2007 7:09 PM In reply to
    • Calvin
    • London
    • Posts 233
    It's an Optoma EzPro 610H
    If anyone lives in the states (where they're much cheaper) and wants to buy and post as a "gift" to help me avoid import taxes, it would be awesome. If not, I may just buy one from the UK website and get another one when I'm over in Louisiana in March
  • 12-05-2007 5:22 PM In reply to
    • Calvin
    • London
    • Posts 233
    The solution:
    I thought I'd share this. I eventually went to a place on Tottenham Court Road (which has dozens of electronics stores) and after some discussion and haggling, managed to get a projector for £380.I'm now selling my old one (minus bulb) for £200 on Gumtree.  What I have now is maybe not as bright but it's far more suited to my situation, small room and needs. Effectively I've bought a new projector for (once I sell the old unit) less than the cost of a new bulb. I also checked and the bulbs for the new unit (whilst not exactly "cheap" int he normal sense) are much cheaper thanfor the other one.
  • 12-05-2007 10:08 PM In reply to
    I also have a projector with a dead bulb. I wish you luck selling yours, but it seems to me few people are prepared to buy such equipment, presumably because they can't see the thing working and check it for other faults. This HP model I have still retails for £1500, (somewhat inflated figure IMO), but sans bulb, looking at ebay sales, I think I'll be lucky to get £200. I was thinking of approaching a projection hire company or bulb seller to see if they are interested in making an offer, since they may be interested and would be able to test before parting with any cash.
