Hi all.
I heard that you can play video clips on BeoPort with the appropriate codecs, that's all fine and works a treat with my A8's. But I found that when I want the sound to go through my BeoLab 3500 connected to my PC, the BeoLab 3500 turns to standby.
I have spoken to my dealer and he said that it should stay on and the sound should be audible!
Has anyone had the same problem, is it my configuration that is wrong or can I turn the sound on via my Beo4 after the clip has started?
Any ideas?
Regards,
Greg
