Latest post 11-18-2007 1:16 PM by EOB. 0 replies.
Page 1 of 1 (1 items)
  • 11-18-2007 1:16 PM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    Module Surround 5.1 detachment from BC1
    I am trying to take off the module of the surround 5.1 of a BC1.
    Due to the fact that some ( the upper ) of the attaching pins are broken the module as it is top heavy keeps dropping off.
    I still have the original cap with out the module which doesnt need the pins and until I have ordered a new part I want to use at least the unit for TV etc. If I can get the module off its possible to close it up with the original cap.
    Problem is I am unsure how the module is connected? So before I ruin something I guess some advice is very welcome.
    As I see it the best way is to disconnect the module from the BC1 itself. I see a grey sort of connector with something that seems a safe- click system. its possible to manouvre it so it unlocks ?. So my guess is that it will free the connector from its base. If I am right the module is attached to the BC1 with a slim grey connector? When pulled the connector doesnt give way though ?
    Am I missing something or should I use more force? All is not in the easiest spot and the connector seems a bit fragile?
    Hopefully some one can help me out here,.....
    Regards EOB
