Latest post 04-22-2007 4:31 PM by Justin. 9 replies.
Page 1 of 1 (10 items)
  • 04-22-2007 1:40 PM
    the dark side of the bl9
    How do you manage to consider any other loudspeakers after listening to them?NOT boomy at all,excellent balance in the midrange area,still expensive sure but half the price of the beolab 5.I do not want a beolab 2!!What can you do????
  • 04-22-2007 1:48 PM In reply to
    • Graeme
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Aberdeenshire Scotland
    • Posts 194
    Re: the dark side of the bl9
    Is this your new set up in your avatar
    Very nice indeed, it looks fantastic and I have heard them too, they are very nice sounding speakers......congratulationsMusicYesCool
    Cheers Graeme
  • 04-22-2007 1:51 PM In reply to
    if it is, you need to expand the space between the speakers for better stereo quality.
  • 04-22-2007 2:01 PM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    I believe Christophe's avatar is one of the first photos that was out of the BL9's.
    Correct me if I'm wrong Smile
  • 04-22-2007 2:04 PM In reply to
    • Pushkin
    • Not Ranked
    • Joined on 04-19-2007
    • London
    • Posts 50
    I agree - an excellent choice and looks very good - I too was very impressed when I heard them.
  • 04-22-2007 2:06 PM In reply to
    mine hopefully arrive next week, so maybe I'll be no.2 with a BL9 avatar! Can't waitSmile
  • 04-22-2007 2:25 PM In reply to
    I'm afraid I do not own them yet,I found the picture in the old forum,but anyway I'm still wondering what to buy with them,I need a new home cinema set up but my budget is limited and I definitely want the beolab 9 to be part of it.What do you suggest?
  • 04-22-2007 3:02 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    For a home cinema with BL9, I think there are some great options :
    BL9 front+BL3 rear+ BL7.4 center (full ALT setup) with a beosystem 3 (the most futureproof item of B&O) and a Panasonic plasma (Beovisions 4 are extremely overpriced for what they are : a simple plasma display without B&O electronics, if you want you can buy aluminium frames to make the Pana look more B&O!)
    You can make a cheaper system with BL6000 or BL4 at the rear, it will not be full ALT, but I think it's not useful to place too high quality speakers at the rear.
    Personnaly, I would avoid a BV7 for its lack of connectivity, for the sound processor which is not as good as the Beosystem 3 and for its integrated DVD which will become useless as soon as you will buy a HD player. (the price of the BV7-40 without speaker is very close to that of the Beosystem 3 with a panasonic 42" Plasma panel, and there is no comparison possible technically)
  • 04-22-2007 3:51 PM In reply to
    Thanks mbee,I'd say beosystem 3 + 7.4+panasonic plasma are even cheaper than a beovision 7-40 with 7.2 or 7.4,the panasonic monitors are a real bargain in France at the moment!
  • 04-22-2007 4:31 PM In reply to
    mbee, just wondered if you've had a demo yet. In particular you mention you don't want a lab2.
     I agree it wasn't needed with just music cds, but when I played a dvd I thought that there was something missing in the deep base when playing the opening scene of the Fifth Element
