Latest post 11-19-2007 10:52 AM by The Stig - ver. 1.7. 2 replies.
Page 1 of 1 (3 items)
  • 11-17-2007 11:49 AM
    static noise
    hi this is my first time on the forum and was wondering if any one could help me out,i have a beocentre 2 with a beovision 3 beolab 3 front speakers and beolab 4000 as rear speakers i am getting a static sound ,only faintly but still anoying from the left speakers front rear and t v depending on  the  speaker setting i use, this only happens with cds but not if i use the dvd setting on the remote hope this makes sense thanks shaun.
  • 11-17-2007 12:57 PM In reply to
    Re: static noise
    What sort of Powerlink cables are you using? They should be Mark 3 with the small triangle mark on the plugs. Beolab 3s are very sensitive to interference and the cables need to be the shielded ones.
    From what you say though, I would suspect a fault in the Surround Sound module of the BV3. Have you tried connecting the speakers just to the BC2 to see if there is any static there? I would guess that it will be fine. If it is, I would suggest getting the module looked at. Is it still under warranty?
    Welcome to Beoworld.
  • 11-19-2007 10:52 AM In reply to
    Re: static noise
    Sounds to me like a Master link fault maybe, when you use the DVD command the sound is transfered by the scart cable.
