Latest post 11-23-2007 11:32 AM by auric. 9 replies.
Page 1 of 1 (10 items)
  • 11-16-2007 1:33 PM
    Philips CDM 1 on Ebay
    Friends:
    Anyone looking for a CDM 1 laser? It is not my listing, I've never dealt with the seller but if you need the part, it is a reasonable price.
    http://cgi.ebay.com/Philips-CDM-1-laser-pickup-Studer-Revox_W0QQitemZ180178719523QQihZ008QQcategoryZ20831QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    Derek
  • 11-17-2007 12:33 PM In reply to
    Re: Philips CDM 1 on Ebay
    Would this fit in my Beocenter 9000?  It's cd player hasn't worked for sooooo long.  Does it matter if it's 110 or 220 volt beocenter?
    Guy
  • 11-17-2007 8:40 PM In reply to
    Guy:
    CDM 1 goes in CDX but not sure not likely for 9000. Graham perhaps you can confirm?
    The only difference between 110/220 systems in general is the power transformer (assuming that it does not support multiple voltages). Everything else after that is the same.
    There are people here that know how to repair the CD mechanisms on the component level. If interested perhaps you can ask for a reference.
    Regards,
    Derek
  • 11-18-2007 11:56 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Yes, it looks like the one used in the good old 14-bit Beogram CD X (where it practically never fails, check those caps !).
    It will definitely NOT fit in any newer players.
  • 11-18-2007 5:34 PM In reply to
    OK guys...thanks Smile.  Are there any "other company" cd players that I could swap the cd mechanism into my BC 9000?
    Guy
  • 11-18-2007 9:06 PM In reply to
    Guy:
    I think you are better off sending your unit off to one of the specialists here (either directly or ask for referal). These things are old, and as Martin and others have pointed out it could very well be capacitors that have gone bad. Any "swap" you may do will likely be prone to the same problem or may exhibit it soon. The key is finding someone that knows how to repair the pickups at the board levels since B&O is no longer able to provide replacements.
    Also swapping is not easy. This is because the cosemetic piece (the black bottom plate) is glued onto the top of the CD transport. Swapping the assembly will involve transfering that piece over. Its not as straight forward as plug and replace.
    Derek
  • 11-19-2007 7:48 PM In reply to
    OK...thanks Derek.  I hope someone here in North America is interested one day in having a look at it.
    Guy
  • 11-19-2007 9:02 PM In reply to
    Guy:
    I didn't know that you are located in NA. If interested send me a private message I know an authorized service depot that will debug on the board level.
    Derek
  • 11-22-2007 9:05 PM In reply to
    Smile
    OK Derek, private message sent.
    Thanks!
    Guy
  • 11-23-2007 11:32 AM In reply to
    Guy:
    I replied to your PM. Did you get my response?
    Check your in box?
    Derek
