Latest post 11-15-2007 5:46 PM by vinnie21. 5 replies.
Page 1 of 1 (6 items)
  • 11-15-2007 4:18 PM
    BV7 and BC2
    Just wired my BC2 to work through my BV7-40 out to my BL9's. Works brilliantly.
    When I press CD on the remote, the tv turns off and the BL goes on.. so far so good... Butt... Some times I want to listen to BC2 when also watching thwe BV7-40....
     How can I do that ?
     The Dane
    Maybe this is as good as it gets... BV7-40 MKII, BL9, BC2, BL6000, MX4000, Beosound 3, HDR1
  • 11-15-2007 4:52 PM In reply to
    Re: BV7 and BC2
     It should be as simple as scrolling through LIST until you find AV then pressing the source you would like to listen to, ie radio or CD. You may have to add AV to your Beo4 by pressing standbye and list together, it will ask you if you want to add? press Go and scroll through the options until you get AV and then press Go.
    I hope this helps.
     Vinnie.
  • 11-15-2007 5:19 PM In reply to
    Re: BV7 and BC2
    Thanks Vinnie, but don't that close down the TV when doing it ?
  • 11-15-2007 5:38 PM In reply to
    Re: BV7 and BC2
    No I dont think so, you are basically asking the BV 7 to give you Audio and Video at the same time. If you are watching DTV you will be able to mix Video with audio from another source ie the CD or Radio on the BC2.
  • 11-15-2007 5:43 PM In reply to
    Re: BV7 and BC2
    You will only be able to change radio station channels or tracks on your CD's though. You will have to come out of the AV command by pressing DTV again to change channels and then back into AV command to mix video and audio again.
  • 11-15-2007 5:46 PM In reply to
    Re: BV7 and BC2
    I take it you have the BL 9 connected to the BV 7? If they are connected to the BC2 the above will not work, I dont think it will anyway.
