Latest post 11-15-2007 10:28 AM by hebo. 3 replies.
Page 1 of 1 (4 items)
  • 11-14-2007 2:15 PM
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    Anyone tested TOPFIELD 5710PVRtHDMI as STB???
    I would like to have the TOPFIELD 5710PVRtHDMI as STB-source.
    Anyone knows if its possible to add this one in the STB-list?
    I have tried TF4000, TF5000PVR and TF5800PVR but none of them worked.
    It´s a BV6-26 with STB-table 3.9
     BV10
  • 11-15-2007 8:23 AM In reply to
    • hebo
    • Sweden
    • Posts 305
    Re: Anyone tested TOPFIELD 5710PVRtHDMI as STB???
    Anyone?
    Is it really different IR-codes from a TF5800 and a TF5000?
    Is there anyway I can try another brand and see if it works? Tips?
    Regards
    Hebo
     BV10
  • 11-15-2007 9:21 AM In reply to
    Hebo,
    Whilst I have not tried a Topfield 5710 PVR, like most manufacturers they rarely change existing IR codes from previous models. They may add new codes not previously used however.
    B&O have produced STB generated codes for the following Topfield models
    TF4000 T/COT
    TF4000 PVR N
    TF6300 IR
    TF4000PVR
    TF5000PVR
    TF5800PVR
    Regards Keith....
  • 11-15-2007 10:28 AM In reply to
    • hebo
    • Sweden
    • Posts 305
    Thanks Keith,
    I tried TF4000 T/COT, TF5000PVR and TF5800PVR with no luck!
    I have to see if there is any model supported for sale in Sweden....
    Anyone with experience of Topfield-box with STB-controlling
     BV10
