Latest post 11-14-2007 5:38 PM by Alex. 7 replies.
Page 1 of 1 (8 items)
  • 11-14-2007 11:33 AM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Beolab 8000 as Laptop speakers????
    Please excuse my ignorance (yet again....)
    Would it be possible with the use of an adapter lead to run 8000s off a laptop, or even an ipod? If so, are the leads available only from B&O?
    Cheers
    Nigel
  • 11-14-2007 11:51 AM In reply to
    • kallasr
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Beolab 8000 as Laptop speakers????
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-14-2007 11:56 AM In reply to
    The BeoLab 8000s are such high-quality speakers that it would be a shame to feed them with the direct output of the in-built DAC (digital-to-analog-converter) in a Mac or in an iPod. These in-built DACs are OK but far from audiophile, while your speakers are.
    I would recommend a stand-alone DAC between your laptop and your BeoLab 8000s. These you can get from about GBP 400 to GBP 1000 - the advantage being that you can run the digital signal from your laptop to the converter, and then run analog cables from that to your speakers.
    For instance, if you get the Konnekt 24D from t.c.electronics you can go via Firewire from your laptop to the Konnekt, and then go via the Monitor Line-Out from that to your speakers, while having a volume control in the Konnekt that is very precise.
  • 11-14-2007 1:21 PM In reply to
    Aw man, why didn't I think about something like that to go from my Mini to the Beolink?  Or my Airport to the Beosound?  I've got a Firewire one AND a USB one that I'm not using anymore.
  • 11-14-2007 2:42 PM In reply to
    Also be aware that when you use the Mac's Equalizer in iTunes and its pre-amp to control sound output volume to active speakers you are definitely degrading the sound. In fact, the DAC manufacturer Benchmark recommends deactivating Equalizer and keeping output volumes from the Macs at maximum (while also unchecking certain preferences in iTunes) in order to avoid having the inferior soundcard in the Mac process the sound before it is ported.
    Which is why a stand-alone DAC is recommended. (Certain receivers have Toslink optical IN which will also accept a digital stream from your Mac.)
  • 11-14-2007 3:57 PM In reply to
    Top notch info here! Cool Thanks Graham, this has been useful to me too!
  • 11-14-2007 4:00 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    It might look a bit odd on the train.
    Poor me, never win owt!
  • 11-14-2007 5:38 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    When connecting directly to the speakers, you'll want an in-line volume control from Maplins. £3.99 it cost me. My BeoLab 4s were uselessly loud (even on their 'PC' setting) when used with my MacBook Pro, but this little thing has done the trick with no fuss...
     Weekly top artists:
