Latest post 11-13-2007 9:49 AM by PhilLondon. 7 replies.
Page 1 of 1 (8 items)
  • 11-13-2007 4:23 AM
    Appletv on my BV7
    I am excited as my BV 7 arrived today and I had an AppleTV hooked up to it by HDMI
    AppleTV will be mainly used to play my itune library.
    Unfortunately I ran into a little problem, when ever I play music, the centre speaker (bl7.4) + 2 bl 9 all produce sound.
     Is there anyway for me to switch off the centre speaker on BV7 while I play music thru Appletv??
  • 11-13-2007 4:55 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Appletv on my BV7
    SPEAKERS then 2.
    Details:
    on Beo 4 press LIST until SPEAKERS appears, then 2 for selecting just the left and right front ones.
    To add SPEAKERS to the LIST button: hold down the red dot button (POWER OFF) and press LIST (release red dot button), up/down for ADD? then GO, choose SPEAKERS, that's it.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-13-2007 5:29 AM In reply to
    Thanks for the quick reply!!  its really good now!  :0
  • 11-13-2007 7:31 AM In reply to
    Idea
    If you want your B7 to do it automatic, just add AV-PC in your remote. Your tv has to be in V.Opt 2.
  • 11-13-2007 7:40 AM In reply to
    DoubleU:
    Idea
     That would turn the screen off as well...
  • 11-13-2007 7:46 AM In reply to
    How convenient...
    Unless you want to watch your library all day.Wink
  • 11-13-2007 8:38 AM In reply to
    What if I want to use it to watch movies streaming from itune?
    Change it back?
  • 11-13-2007 9:49 AM In reply to
    It is airport express that does streaming (and you control what plays from your Mac or PC).
    The Apple TV needs to be controlled from its interface.
    You can of course choose a song/playlist and then turn the screen off...
     p.
