Latest post 11-12-2007 5:27 PM by Emil. 3 replies.
Page 1 of 1 (4 items)
  • 11-12-2007 3:53 PM
    • Emil
    • Top 500 Contributor
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    BeoVision 5 - dark picture
    A while ago I had to replace the chassis of my mkI BV5 due to a faulty ML contact. After this I have noticed that the picture seems much darker than before. Since the chassis replacement meant that the software was changed as well I suppose that this may have caused my problem.
    I have set brightness to 50 (out of 60) but it is still hard to differ one black shade from another. All black colours just seems…black. And if I go any higher black tends to become grey.
    I suspect that some of the settings in the service menu must have changed but I do not know how to access the service menu (if advisable at all) or which the factory settings should be.
    Anyone who can advise how to solve this problem?
    Regards,
    Emil
    Inflagrante
  • 11-12-2007 4:33 PM In reply to
    • Beolab
    • Top 150 Contributor
    • Sweden
    • Posts 535
    Re: BeoVision 5 - dark picture
    Du har PM !!!
    BL8000 MkII Black
  • 11-12-2007 4:57 PM In reply to
    • Rolf
    • Not Ranked
    • Joined on 04-21-2007
    • Stockholm, Sweden
    • Posts 63
    Since I have the same issue maybe you could post the reply in this forum if you have an answer.
    Tack på förhand
    Rolf
  • 11-12-2007 5:27 PM In reply to
    • Emil
    • Stockholm, Sweden
    • Posts 98
    Thanks for the info Fredrik! Will probably give a call to my service technician.
    Rolf - I have sent you a pm.
    Regards,
    Emil
    Inflagrante
