Latest post 11-14-2007 2:46 PM by MikaelB. 2 replies.
Page 1 of 1 (3 items)
  • 11-12-2007 2:16 PM
    • MikaelB
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    Sad [:(] BeoPort 4.65 installation fails on Windows Vista
    I am moving my BeoPort box to my new Windows Vista computer. I have downloaded the new BeoPort 4.65 version from the official website.
    It runs fine until after "installing components..." there it says "Error occurred during USB driver setup. Aborting installation."
    I also tried to run the setup.exe as administrator (by right-clicking it), but the same error occurs.
    What am I doing wrong?
    /MikaelB
  • 11-12-2007 3:38 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: BeoPort 4.65 installation fails on Windows Vista
    I take it the device is not yet connected - its normal practise to install software before connecting the usb device.
    Although after a little looking around it seems Beoport 4.65 may not be fully Vista compatible - some seem to have it working but most don't, although there is mention of an upcoming Vista compatible release
    http://www.bang-olufsen.com/Community/forums/thread-view.asp?tid=5602
    http://forum.beoworld.org/forums/thread/57741.aspx
  • 11-14-2007 2:46 PM In reply to
    • MikaelB
    • Herning, Denmark
    • Posts 191
    Yes you are correct - I have not yet plugged the USB cable into the computer.
