Latest post 04-22-2007 1:52 PM by benkap. 7 replies.
Page 1 of 1 (8 items)
  • 04-22-2007 8:29 AM
    • benkap
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Oslo, Norway
    • Posts 162
    Tuning an MX4000 w/ a Beo4 - is it possible?
    Just wondering if there is any way to tune an older MX4000 with a newer Beo4.
    Normally you would have to press the GO TO button on a Beolink 1000 but is there any way to get around this?
  • 04-22-2007 8:50 AM In reply to
    Re: Tuning an MX4000 w/ a Beo4 - is it possible?
    Do  you not just go to V.Setup in the list (Add if necessary) and use the TUNE button?
  • 04-22-2007 9:17 AM In reply to
    I never found a way to do this with a Beo4. I think you need a beolink 1000
    Regards Graham
  • 04-22-2007 9:45 AM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    Peter:
    Yes! Thank you, Peter Smile
  • 04-22-2007 10:14 AM In reply to
    Yes, but if I recall, you have no "store" button and "go" does not work??
    Regards Graham
  • 04-22-2007 11:05 AM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    joeyboygolf:
    When you enter the V.SETUP menu there is a STORE button in the list.
  • 04-22-2007 11:22 AM In reply to
    Never found that, oh well you live and learn!
    Regards Graham
  • 04-22-2007 1:52 PM In reply to
    • benkap
    • Oslo, Norway
    • Posts 162
    joeyboygolf:
    What I did was: V.SETUP GO GO then tuned and named the channel, pressed LIST twice and then GO
    Should do the trick
