seanklemis: two questions really
1) how can i change my email that i use for beoworld as when i go to update profile it does not have the option to change email address???
2) Is beoworld doing email forwarding again?
Click on your underlined username at the top right of this page (assuming you are logged in) and then select the email tab - you can change it there.
Not sure about the email forwarding - don't think so.
