Latest post 12-08-2007 9:21 AM by koning. 10 replies.
Page 1 of 1 (11 items)
  • 11-10-2007 10:57 AM
    bs-9000 pin protection
    when my bs-9000 asked for the pincode I stopped the power.
    6 days later when I turned the power on nothing happend.
    standbye led turned on,but cd or radio are not working
    every 5 minutes  you hear a click and the led turns off and on.
    Is mine bs-9000 dead or is it the pin protection?
  • 11-10-2007 11:19 AM In reply to
    Re: bs-9000 pin protection
    It is likely that a fault has occurred on your Beosound 9000, possible intermittent.
    Switch the unit off and remove all connections, masterlink etc and then switch on again and see the results
    Regards Keith....
  • 11-10-2007 12:02 PM In reply to
    everything is removed still the same problem.
    How long will it normally take when the beosound is in pincode protection?
  • 11-10-2007 12:41 PM In reply to
    What version of Beosound 9000 do you have? if you do not know, then how old is the unit ?
    Regards Keith....
  • 11-10-2007 2:00 PM In reply to
    type 2571 markIII year 2001
    Now after six hours the led goes two time on and off!
  • 11-11-2007 8:19 AM In reply to
    Is there anyone who knows what this could be
  • 11-11-2007 9:46 AM In reply to
    We do have the service manual for this model but I would suggest that it won't get you very far! I think this needs to be seen by the service department.
  • 11-11-2007 10:57 AM In reply to
    I am assuming that you have your pin code ? please confirm..
    On this version of the Beosound 9000 the pin code can be de-activated, if it was previously de-activated, i.e. if you turned the power off for a while, on switching it on again, it did NOT ask for a pin code, but due to some problem it has been re-activated, then you will need the pin code to put it back to its previous state.
    So, what happen just prior to the problem occuring ?
    Regards Keith....
  • 11-11-2007 12:24 PM In reply to
    i didn't have the master code,only my own personel code.
    Power as been off about an hour,when the power was on the beosound asked for the pincode.
    Then I pulled the main power off.I did that 2 times
    Now I can not activate my pin code because the buttons don't work anymore
  • 11-11-2007 1:58 PM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    You may have a dead lock - I would recommend you to bring it to your dealer for a hard reset, that should solve your issue. If not, your dealer can do a read-out of the error code(s) and check them against the service manual.
    Roger
  • 12-08-2007 9:21 AM In reply to
    Processor and sw eeprom are replaced.
    Everything o.k now.Smile
    Thanks fred b
