Hi Craig and anyone else following this problem
I have just inherited the Beomaster 1200 with the Beogram1000 type 5202 in it. Unfortunately the turntable runs too fast in all table speeds. I have checked voltages, the input voltage is 255V (house voltage) and the output to the motor is 16V rather than the required 14V. That is why it is running too fast, the problem is why. I have checked several resistors, the 1k ones all seem ok but a couple of the 22k (namely 16&17 on the pcb circuit diagram) only show 8.8k. I am thinking that this could be the reason. Any thoughts out there???
Could I place a potentiometer (varisistor) to take the voltage down from 16V to 14V - everything else seems to work ok?
The above might seem a little technical but I am a complete techno weeb really so easy english please.
thanks for your support
Keith
