Latest post 11-08-2007 7:44 PM by grestmit. 6 replies.
Page 1 of 1 (7 items)
  • 11-08-2007 2:15 PM
    • grestmit
    • Not Ranked
    • Joined on 11-08-2007
    • Eugene Oregon U.S.
    • Posts 7
    Need New Belt
    I found a BO Beogram 4002 Turntable at a garage sale for $20.00 so I bought it. The guy didn't know what was wrong with it. I took the platter off and found it needs a new belt. Does any one know where to get one and how much they are?  Also, is there any thing else I should look for while the platter is off?Unsure
    Greg
  • 11-08-2007 2:29 PM In reply to
    Re: Need New Belt
    Martin (Dillen on site ) can get you belts. You will need the Type number. There are actually two belts - one for the platter and one that drives the arm. I would get those first and see if there are any other problems at that point!
    Nice purchase!
  • 11-08-2007 2:55 PM In reply to
    • grestmit
    • Not Ranked
    • Posts 7
    Re: Need New Belt
    Who is Martin [Dillen] and where do I find him?  Also, how do I take it apart to get to the other belt?
    Greg
  • 11-08-2007 3:56 PM In reply to
    Re: Need New Belt
    These decks come apart very easily. The wooden surround pulls forward and then you can remove all the metal panels. It takes a little practice to put them back. I wouldn't be too surprised if you find the old belt somewhere in there!!
  • 11-08-2007 4:40 PM In reply to
    • grestmit
    • Not Ranked
    • Posts 7
    Re: Need New Belt
    It came apart just as you said.  I found a place online to get the belts; www.turntablebasics.com , so I bought them. They were $15. I'll see how well they work when I receive them.
    Greg
  • 11-08-2007 4:46 PM In reply to
    Re: Need New Belt
    You suddenly realise how easy it is to change the belt!! For years I had one heck of a struggle! Laughing
  • 11-08-2007 7:44 PM In reply to
    • grestmit
    • Not Ranked
    • Posts 7
    Re: Need New Belt
    Thank's for the help, I just wish my Vette could be fixed that easy.Wink
    Greg
