Latest post 11-09-2007 9:35 AM by kawo. 2 replies.
Page 1 of 1 (3 items)
  • 11-08-2007 12:52 PM
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    Test: MacBook Pro with FrontRow vs Toshiba XE1 for DVD play back
    Hi All,
     as I have managed to get my new MacBook Pro up and running and with the new cool FrontRow in Leopard I tried to compare the Audio and Video perfromance of the two devices.
    The setup is a Beosystem 3 with a Panasonic Plasma 50" TH-50PH10, two Beolab 5 with 7-4 as Center and two Lab 3 as rears speaker. The Toshiba is connected via HDMI to the BS3 (video and audio) and the Macbook with a VGA to the PC input and also with a HDMI adapter to a HDMI input of the BS3. Sound from the Macbook feeds via a Toslink/SDIF converter into the BS3.
    The Test DVD for the afternoon was Peter Gabriels "Growing Up" which I have ripped to the Macbook. After 1 hour switching back and force I have to say that there is (just) a little difference: The audio performance of the Tosh is a little bit more precise and has a little more room than the Macbook. Not sure if this difference is caused by HDMI vs. TOSLINK, I need to do a further test. But with the lab 5 I can here a difference.
    Also the scaler in the Tosh does a slighly better job, regardsless if the Macbook is connected to VGA or HDMI. But again, very small differece!
    So as a conclusion, a Mac will do a great job as media center! Santa Claus has now a MacMini on the list Big Smile
    cheers
    kawo
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 11-09-2007 3:02 AM In reply to
    Re: Test: MacBook Pro with FrontRow vs Toshiba XE1 for DVD play back
    A few pointers, to help you ensure pitch perfect sound out of the Mac.
    In your DVD Player, Preferences>Disk Setup>CHECK Disable Dolby Dynamic Range Compression.
    Always make certain that all volume settings are at maximum. With the Toslink connected it should default to that, but just check to make certain that you don't have a lower volume setting in SysPref>Sound; Audio MIDI Setup, etc.
    Also, make certain that your iTunes isn't using Equalizer - uncheck that.
    Likewise, in your iTunes Preferences>Playback - uncheck Sound Enhancer and Sound Check.
    Last, but not least, you have to set the proper sample rate for the material you are playing. Usually this is 44.1kHz for CDs, but with certain movie sound formats at higher sample rates you want to set the proper rate to ensure that your Mac isn't reconverting before sending it out.
    Set the bit rate at the maximum your setup will permit - usually this is 24bit, though some sound cards permit 32bit. This is just to ensure your various material has enough headroom and doesn't get "downconverted." BeoSystem 3 can handle up to 32bit/192kHz.
    Some sound cards set the rate automatically, but usually it has to be done manually. Benchmark has a nice wiki concerning this on Macs.
    Now you're set! And you may actually find that your Toshiba got a challenge!
    The biggest sinner here is the Dolby Dynamic Range Compression - it's used to help the small speakers in laptops and earbuds not jam up when there are sudden leaps in dynamics; but you don't want that limiter on through your great speakers!
    It's also worth it to ensure you are using the right speaker configuration setup for multichannel in Audio MIDI Setup.
  • 11-09-2007 9:35 AM In reply to
    • kawo
    • Posts 516
    Thank you for all your help! I will do some more testing soon.
     kawo
