Hi all,
So far, the setup with multiple LC2's works great,
with Beolink 7000 i use the timer, and so on.
One LC2 however isn't working properly.
- On/off/dim functions normal by touching the dome.
The problem is when i try to control it by remote,
sometimes it works, but most of the time it doesn't respond to remote.
Disconnected all other LC2's from the mains and checked again, no change.
I've searched the forums for information,
and have read about problems with the touch-sensitive dome,
but not about the infrared not working.
I have not (yet) removed the dome, from what i remember,
the dome/touch-sensitive part is the most delicate part, which functions normal.
Does anyone have the Service Manual of the LC2,
or knows what the problem might be ?
Thanks !
