Latest post 11-02-2007 9:38 PM by jvezina. 4 replies.
Page 1 of 1 (5 items)
  • 11-02-2007 12:17 PM
    • Lagom
    • Not Ranked
    • Joined on 04-18-2007
    • New Orleans
    • Posts 35
    CableCARD and QAM tuner
    Hello,
    Does anyone know if Bang & Olufsen will offer a CableCARD or QAM tuner in their video products, which could include the BS3?
    I happily own an Avant, but am hoping both of these components will be added.
    Thanks for your time.
  • 11-02-2007 2:40 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: CableCARD and QAM tuner
    as far as i know, only DVB-T (terrestrial) and DVB-S (satellite) are built into some B&O products
    (or are available as option)
    BeoSystem 3 has a PUC (Peripheral Unit Controller), which lets you control external devices,
    such as Set Top Box.
    The slots in BeoSystem 3, f.e. the PCMCIA and SMARTCARD-slot are for satellite (unsure)
  • 11-02-2007 2:48 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Just noticed (comparing BeoSystem 3 Reference Guide of the European and US version)
    that the US version of the BeoSystem 3 is different and doesn't seem to have
    the additional PCMCIA and SMARTCARD-slots.
    US version of BeoSystem 3
    European version of BeoSystem 3 :
     But even without these slots, i'm pretty sure that you can control the cable-tuner with it.
     I'm sure there are other who can tell you more about this. Smile
  • 11-02-2007 4:08 PM In reply to
    • Lagom
    • Not Ranked
    • New Orleans
    • Posts 35
    Ignace,
    Thanks so much for the side-by-side comparison.  Perhaps, there is a licensing issue that prevents the addition of these components in the US at this time.
    I see so many new TVs at the store that feature CableCARD.  (I only look, as I would not consider the idea of any products that lack Masterlink.)  There is also a new format for CableCARD that allows for two-way communication.
  • 11-02-2007 9:38 PM In reply to
    The built-in ATSC tuner of the North American Beosystem 3 as well as the one in BV-7 and BV-9 already supports QAM: it can receive UNENCRYPTED digital cable channels (including standard definition and audio only channels). I have tested it on my own set.
    To enable QAM reception, you have to set "Cable" instead of "Antenna" in the setup menu of the digital tuner (DTV).
    Cable cards are another story: apparently this is a dying system since cable companies want to sell set top boxes that are more easily customizable to provide pay per view TV or other services. In Canada, no cable company supports cable cards. So perhaps B&O will never offer that possibility.
    Sony TVs sold in Canada also only provide "clear QAM " (unencrypted)  reception.
    Regards,
    Jean
