Latest post 11-02-2007 12:07 PM by PhilLondon. 8 replies.
Page 1 of 1 (9 items)
  • 11-01-2007 12:19 PM
    Which Beogram for a BeoCenter 9500
    Which BeoGram is compatible with a Beocenter 9500?
     p.
  • 11-01-2007 12:37 PM In reply to
    • V13WNG
    • Top 500 Contributor
    • Joined on 06-11-2007
    • Eastbourne, East Sussex, ENG
    • Posts 200
    Re: Which Beogram for a BeoCenter 9500
    Well, the BeoGram 9500 would be a logical starting point Stick out tongue, but you're going to struggle to find one!! You'd be best with one of the slanted decks - they'll look better alongside your 'Center.
    Remember, the BeoCenter 9500 has an inbuilt RIAA pre-amplifier, so you'll need to avoid BeoGram 3500, 4500, 6500 and 7000, which already have the RIAA inbuilt to the deck.
    Muchos Gracias Cool
  • 11-01-2007 12:52 PM In reply to
    Has the BC9000 got an RIAA as well?
     p.
  • 11-01-2007 12:58 PM In reply to
    • V13WNG
    • Posts 200
    Yes, it has! The's a BeoGram 9000, but it's square shaped, like the 5005 / 5500. Goodness knows why they didn't match it with it's intended system!
    Muchos Gracias Cool
  • 11-01-2007 3:16 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Never could understand why the BG9000 & 9500 were not very good matches in shape to the Beocenter 9000 & 9500. If someone does know the answer to this, I would be very interested to hear why.
    CraigSmile
  • 11-01-2007 3:31 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    The 9500 does have the sloping lid Craig, it's just the 9000 which is Volvo shaped (boxyStick out tongue) goodness knows why thoughConfused
    Chris.
  • 11-01-2007 3:37 PM In reply to
    • ScottMc
    • Not Ranked
    • Joined on 06-12-2007
    • Ayrshire
    • Posts 37
    you could also use a beogram 2000 - this is what i am doing with my beocenter 8500.
    It will be much easier to find and cheaper to buy as it is not a tangential deck. It doesn't have the "slant" lid but i don't find that this is much of a problem since i don't place it up against my beocenter anyway.
    also it is fully datalinked so you can control it via your beolink remote.
  • 11-01-2007 3:48 PM In reply to
    • Craig
    • Posts 4,855
    Medogsfat:
    Chris.
    Well you learn something new every day.Embarrassed I always though they were both the same shape. All that was different was the finsh of the metal panel on the top.
    CraigSmile
  • 11-02-2007 12:07 PM In reply to
    wtlc2zpx:
     p.
     While searching I found a good thread about this subject, so I am linking it here:
     http://forum.beoworld.org/forums/thread/8720.aspx
