1st March February 2012
11-01-2007 8:17 AM
rickluuk
- Joined on 11-01-2007
- Posts 3
The tube of my Beovision 3 just brokedown, after 6 years already. Now I am considering to buy a Beovision 8 32" , but this one doesnot have a surround sound module. Will this be available soon?
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Just replace the tube! 6 years isn't very long, and the BV8 will never have a surround module.
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Press information:
Why is a DSS module not available? BeoVision 8 is designed and positioned as the flexible television meant to be used for casual entertainment, not dedicated home-cinema viewing - for this purpose concepts like BeoCenter 6-26, BeoVision 7, BeoVision 9 and BeoVision 4 are recommended. However, remember that it is possible to add two extra speakers and a subwoofer to BeoVision 8 for a more powerful and intense sound experience.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Well this is the first time I have heard of the Tube going in a BV3. Mine is 3 Years old this Month, I hope it has nore than 3 Years life left in it. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
6 years isn't very long.. i have to wonder if there is some outside influence that has caused the tube to go. I'm not sure that the BV3 has a better picture than the BV8. BV8 is pretty awesome on picture but the sound isn't as good as the BV3 on sound, although still very good. Do you use your BV3 for surround sound, because if you just want to add a pair of speakers you can just plug them into the BV8. jazz
meandmyshadow
- Posts 339
rickluuk: The tube of my Beovision 3 just brokedown, after 6 years already. Now I am considering to buy a Beovision 8 32" , but this one doesnot have a surround sound module. Will this be available soon?
First thing to do is get your dealer to check the useage, if it is shown to have had very little use in the 6 years that you have had it, B&O may consider replacing the tube and you pay the engineers charge. If however it shows that the TV has had a lot of use they will not. I know a couple who's Avant tube blew after about 6 years, they insisted that they did not watch that much television. This was true but on calling up the service menu it showed use of about 20,000 hours. After some conversation, it turned out that almost every day she would put on the digital radio via Sky, what she did not do was turn off the screen. The Avant had an image on the screen for about 12 hours a day, nearly every day. I'm not suggesting that this is the case for you but if the BV3 has only light use B&O may be sympathetic. Not guaranteed though.
meandmyshadow
- Posts 339
saf:True ... On the one hand I agree that 12 hours of watching TV everyday is quite a long time (luxury to some  , perhaps), but on the other hand, there is nothing mentioned in the B&O manual eg, that if you do that and the product fails it's your 'fault' ...
No, it isn't the individuals fault, infact in this case I would blame the dealer who installed the TV for not telling them how to mute the picture. But the point is, it was used constantly and therefore the life of the TV in relative years was shorter. We know that on average viewing B&O TV's have a life span of 10 years plus, I personally have an Avant of that age, but in this case it was not average viewing.The point I was making was, if the BV3 has had less use than what B&O consider is acceptable for tube life (I have no idea what that would be, let's say 10,000 hours) then they may offer to help, it would not be the first time.
Tom
- Joined on 04-16-2007
- Luxembourg
- Posts 3,175
I think this is off-topic now, but it sure is interesting: is it the dealers job to show the costumer how to mute the picture?
IMO: no. The dealer shows the basic functions of the product, the rest is up to the costumer and can be found in manuals... or he can ask on beoworld.org
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
meandmyshadow
- Posts 339
I don't know how it works in your country, but in the UK the dealer has a responsibility to install and give full instruction on products they sell. The point I have been making is don't write it off just yet, speak to the dealer, get the service counters, ask B&O and they might be a positive outcome.
Tom
- Luxembourg
- Posts 3,175
I understand what you meant, and I would have done the same.
But would you blame your dealer if he had not told you how to mute the picture and would have the same problem now?
Page 1 of 1 (16 items)
