1st March February 2012
Latest post 09-04-2008 2:13 PM by lausvi. 13 replies.
04-21-2007 12:52 PM
Beo
- Joined on 04-17-2007
- Posts 108
reviews on Form 2 headphone please?
I would like to ask for comments on the audio quality of form 2 headphone, thank you.
many people said it is even worse than the a8 earphone. Do you agree?
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Re: reviews on Form 2 headphone please?
Audio quality is very good IMO. Bass reproduction is particularly good. Only negative point about Form 2's is that they get uncomfortable after a while. Say after about an hour. Had my pair for about 2 1/2 years now and use them almost daily. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
beofan
- North Wales
- Posts 36
Yes I'd agree with previous post by Craig, nothing wrong with audio quality, but they do tend to pinch your ears after about an hour. But on the plus side they do have a very long cable! Dom
Peter
- Joined on 02-12-2007
- Posts 9,572
Read Puncher's review of the A8s. He compared them to Form 2s. I think they are uncomfortable and pretty average headphones myself! The Form 1s are better but have a listen to some good ones and you will realise what you are missing! We are planning a headphone review in the next few weeks comparing B&O and other high end headphones. We shall keep you posted!
Graeme
- Joined on 04-16-2007
- Aberdeenshire Scotland
- Posts 194
@ Craig You use them daily?, on what, your main set up or a portable player i.e Ipod?
Cheers
Graeme
Beo
- Posts 108
well, yes, this is very important. If it is a outstanding partner for portable devices, or if form 2 is good for a home use or professional use headphone?! also, for a B&O product, it costs just 100 US dollars, I wonder if it is just a very basic headphone or it is a mid-range headphone.
jk1002
- Boston USA
- Posts 1,620
You can try the Form 2 out at most Apple Stores in the US (and maybe even elsewhere). I compared them straight to the Bose Triport and they do sound significant better, much clearer. I can't comment on the bass, I wasn't watching out for that, too exited that they kicked the 50$ more expensive Bose into the &*#$. Apple Stores aren't a perfect listening environment but figure they will do OK.
Cheers JK
Peter
- Posts 9,572
I have a pair of Form 2s as well as Form 1s and U70s in addition to A8s and a pair of Sennheisser HD600s. I don't use the U70s - too uncomfortable, or the Form 1s (wife won't give them back!) but also would never use the Form 2s as the sound is just not up to the A8s and the HD600s blow the others away (they should do!) My daughter uses the Form 2s with her Nintendo DS so we don't have to listen to it!
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Peter: Read Puncher's review of the A8s. He compared them to Form 2s. I think they are uncomfortable and pretty average headphones myself! The Form 1s are better but have a listen to some good ones and you will realise what you are missing! We are planning a headphone review in the next few weeks comparing B&O and other high end headphones. We shall keep you posted!
Comparison was actually against against the Form 1s. I've actually re-sent this to LEE yesterday to help out in the "Fake A8" thread.
Peter
- Posts 9,572
The review is actually on in the manual section under A8.
Craig
- Posts 4,855
Graeme: @ Craig You use them daily?, on what, your main set up or a portable player i.e Ipod?
Graeme, i have them connected to my PC. It is in the corner of the Living Room. Normally someone in the house is watching the TV. So I listen to my music whilst on the PC. Craig
wasti
- Joined on 08-29-2008
- Cracow, Poland
- Posts 112
I have got the B&O Form 2 for more than 10 years. Some pros & cons: + good design + long cable
- the comfort of wearing them is very poor - poor durability, especially when it comes to the earpads - you need to exchange them every 6-8 years because they just fell apart even if you don't use them at all! (cost € 14.-) The quality of the sound is OK. But only OK. I would not recommend them unless you are a B&O collector! Cheers!
lausvi
- Helsinki - Finland
- Posts 498
I am just listening music with my Form 1 headphones. I thinki they are of very good quality and they even feel quite good after some time of use. I use them with my MacBook daily. I also have A8's and they are very good, too (I use the A8's also daily with my iPod) In case your Form 1 headphones have lost their original ear pads, the new ones can be bought from LifeStyle AV - I bought mine there. Easily attached and certainly make the Form 1's more comfortable. The only trouble with the Form 1's I've had is that they are only around 40 ohms - some older amps require more
Bang & Olufsen - The art of controlling sound, picture and light
Page 1 of 1 (14 items)
